Question about Polti Vaporetto 2400 Canister Steam Vacuum
Steam won't build up and main generator switch doesn't light up. however,accessory switch light is on
    Sergeant:
  • 273 Answers
Sounds like the heating element has burnt out
Posted on Jul 14, 2009
How do I fix ultra steam mop model s-c393 that will not produce steam
The steam generating element may have failed, in which case it would have to be replaced.
Oct 03, 2016 | Ultra Products GarryTM Ultra Light Vacuum...
Tip
Shark steam mop not producing steam
It is a design flaw having a check valve orifice built into the steam generator.<br />The plastic sleeve gets hot and get hard and shrinks enough to cause blockage at the inlet to steam generator.<br />Also a lot of sediment builds up inside steam generator from impurities in the water which eventually causes a problem and block at the mop head.<br />solution would be to move the check valve from the steam generator to the pump discharge line where it is cooler. and use only distilled water. they should also use a stainless heater element instead of pot metal as it corrodes.<br />
on Apr 24, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
No steam
Have you checked the steam ports for calcium build up?
Nov 13, 2012 | Sienna Aqua Laser Steam Mop
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
No steam is coming out. the orange light is on.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Jun 14, 2011 | Vacuums
Can I use tap water with the S3101WT model
Yes, you can use tap water - either hot or cold.
It's recommended that you fill with clean cold water, but if you fill it with hot water, it will generate steam faster from startup. The most important thing is not to overfill it beyond the MAX mark on the tank.
Mar 07, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Light on doesn;'t steam
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 12, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
565 people viewed this question
Top Polti Vacuums Experts
cwradio73
Kolbrun...
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
