Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson cx4600printer was in storage for 60days&no print on page
Epson cx4600printer was in storage for 60days started using it again after installing new ink cartridges it sounds like its working but nothing is on page color &blackinks are full
    Problem Solver:
  • 28 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppn24
Posted on Sep 04, 2009
  • Epson Master
  • 419 Answers
Ok... the problem is simply that your inkjet nozzles are all clogged from being stored and left unused for so long (presumably it's hot there too which promotes drying out, etc..).
The best way to resolve this is to use a compatible inkjet ink cleaning solution to help break down the clog as follows:
  1. Put the printhead into a cartridge exchange/change position then pull the power lead out of the back of the printer (This leaves the printhead free to move - not locked in the parked position)
  2. Move the printhead out of the way, over to the left side of the printer.
  3. Get your solution in a syringe and carefully soak the parking pad area (the part that the printhead rests on) in the solution until it forms a puddle.
  4. Move the printhead back into the parked position (over the pad to the right) and leave for 24 hours.
This allows the solution to wick up into the printhead nozzles, breaking down the hardened ink clog until it's back into solution. Once your 24 hours is up.
  1. Turn the printer back on and put it through a cleaning routine (if it doesn't do one automatically).
  2. Run a single nozzle check to see how the jets are firing.
  3. Even if there are a few nozzles missing, allow the printer to sit for 30 minutes to allow the ink and nozzles to settle
  4. Try running a new nozzle check and see if you have a full pattern now.
If after all that you still have absolutely no nozzles printing then chances are you may not get it working (or you're using something other than a proper cleaning solution)... If you're finding the nozzles are starting to work it's worth repeating from the beginning.
You may also find that instead of soaking the pad to create a puddle, that it's better to soak a small pad of paper kitchen towel in the solution and place this over the parking pad before moving the printhead back into position. This sometimes "delivers" the solution to the nozzles more effectively by capillary action.
In terms of suitable solutions... the old Windex solution (with ammonia) is recommended by many although personally I've purchased my cleaning solution from my ink supplier as it's formulated to work with the inks I use.
Hope that helps..
Martin
Posted on Jul 15, 2009
I put in a new black ink cartridge in my epson stylus printer. The irst page I printed was very light & spotty in printing. Now there is no print showing on "printed pages" What can I do? I cannot...
Hi Good day!! try the Head cleaning.. to do that follow this method:
1. Click Start
2. Click Settings
3. Click Printer and Faxes now you should view your installed printer.
4. right click your printer and then properties.
5. click "Printing Preferences" and the Printer preferences box there are 5 tabs Choose the "Maintenance"
6. Click "Head Cleaning" to start the cleaning. and then try to print again see if your printing was fine..
if not you should start the head cleaning again..
Regards:
JR
Oct 07, 2010 | Epson Stylus 880 InkJet Color Printer
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
CX5400 Replaced all ink after months in storage
uninstall the printer then reinstall it according to the setup manual.Make sure you are installing the cartridges correctly.Then print a test page form the properties menu
Oct 07, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Printing stops halfway through on Epson LQ300+
you use dpi 180X180 then print full page and speed fast
Jun 25, 2009 | Epson LQ 300+ Matrix Printer
I have Epson Passbook Printer having some printing problem
this is problem of software you are using to print(ie: word ,notepad etc) plz check the setting and try again.
check page setting ,properties,prefrences.
it is due to page layout also(ie: letter,a4,a5 etc)
Jan 24, 2009 | Epson Passbook PLQ-20 Matrix Printer
Epson Stylus dx 7450
It sounds like a driver issue. Have you checked that bothcomputers have the correct driver for your printer?
Mar 18, 2017 | Epson Stylus Multifunction Inkjet Printer/...
Only prints half the page
When this has happened to me I've cured it simply by switching off the printer, waiting a few seconds, then switching it on again!
Sep 25, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
