Question about Gaggia Classic Espresso Machine
Water flowing in steam -but not for coffee -the pump works...
...have cleaned etc etc...
hi - I cannot see any solutions so far.. steveherms problems looks similar to mine - but David's (coffeeservice) description on what to find in the machine does not seem to correspond with my "Gaggia Classic Coffee". The only copper tube goes to the froth-valve - and it is not blocked and even if it was blocked should not hinder the water coming through the head. After dismounting the shower head there is no central bolt as desdribed by David - but 2 large and 5 small holes? No screws in sight...
    Scholar:
  • 32 Answers
I am fairly certain you have a problem with your solenoid valve. See this post.
It's relatively easy to fix, and you might get lucky and "un-stick" your solenoid like I did. The hardest part is keeping track of which wires go where as you disconnect them. I strongly suggest taking pictures and/or labeling with a Sharpie. Otherwise, if you're just swapping out the solenoid, my guess is it will take you about an hour if you're being slow and taking pictures.
Posted on Aug 08, 2009
    President:
  • 1,618 Answers
Here is a breakdown of your machine:
Posted on Jul 15, 2009
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
Initially when the unit said need to prime, no water would flow out of the steam unit. After pulling the pump out and cleaning it, not sure what was blocking water the steam unit now has water pressure,...
I fixed the same issue by pushing in the water knob "in" towards the machine. Machine than primes normally as the water flow is restored and it resets itself.
Dec 13, 2010 | Starbucks Saeco Italia Digital Barista...
Water does not flow through the coffee group but only exits viasteam pipe. Decalcifying and cleaning or resetting factory settings do not solve the problem. what to do?. The problem occurs after I have...
Hi
When you are finished with steaming, try pushing the steam button again and then opening the steam valve to purge the steam. Do this until the water flows freely. You should hear the pump change tone. If you have a pre grind button, try that without putting any coffee in the pre ground chute, then push a medium coffee. Water should flow through the brew unit freely. If not, you are getting a blockage in the brew unit. If it does, your grind on the machine might be too fine. Change to a coarser grind and try again. It usually takes 3 cycles before the grind is in effect.
Aug 22, 2009 | Gaggia Titanium Espresso Machine
Saeco Vienna Deluxe starts brew cycle then red light comes on
Hi
I think you put the tubes on backwards to the flow meter. The inlet side of the flow meter is by the pump and the exit to the pump is by the water tank. They cross.
Jun 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Ventilate warning came on and machine no longer works.
Hi The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Mar 22, 2009 | Gaggia Syncrony Compact Coffee...
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Gaggia Classic Espresso Machine Logo
615 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
