Question about Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012
Describe your Black & Decker Hedge Hog
Describe your Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012 Problem
Trimmer locked up after I snaged a fence wire no visable damage just wont move
  • 279 Answers
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
Broken won't move
Check the teeth for something jamed. Has it set up for many years, maybe rusted bar. Does the motor run? If so maybe a cam gear broken or jam. Does the teeth on the bar move when removed from unit? Or does the motor run when bar removed? To many question to ask need more info.
Jul 04, 2015 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
My 22inch Hedge Hog trimmer (model cht500) 14.4v blades are moving very slowly. Purchased another charger but that did not help the situation. Any thoughts -battery need replacing?
possably the cells in the batt r warn out, take the battery appart nd charge nd c if they r holding charge, if they are you can buy them from a shop on ebay which is really cheap, there probably 1.2 volts, 1400 mha which is tiny. ive got 6800 mha batts in my hedge hog
Mar 12, 2011 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Need diagram of blade assembly for Hedge Hog HS 2400 Type 1. Need to know how the spacers and eccentric are laid out between the blades.
try hulufile.com its a good source for pdf manuals on 2 stroke machines. i hope you find this useful as i use them alot ..
Nov 23, 2010 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Black & Decker GT370-GT371 20 inch hedge trimmer - electrical fault in front handle causing difficulty in starting/resuming cutting. There is no local servicing and help from B&D was restricted...
Your best bet would be to use http://www.eReplacementParts.com as a source to get your Black and Decker parts and than use their tool repair forum and submit this question. They have licensed mechanics that repair these things all the time, so I'm sure they could put together an easy fix.
Sep 28, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Need the handle for B&D power sprayer GSP014, cant find anything on line. ANY HELP? jOE
look at www.toolpartsdirect.com . they have a parts breakdown with part numbers for this.
i dont know where you are but its a us site.
copy and paste the part number for tha handle into your browser , it should come up with results.
Jul 19, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Electic trimmer
You're going to take off like 20 screws including the ones that hold the handle and the hood at the base of the blade. You open it like a clamshell. There is a black plastic cover at the very bottom that covers the gear wheels (one tiny wheel that comes from the motor and a large wheel that actually moves both blades back and forth). The black plastic cover is no attached with screws. You just remove it so you can get to the gears. Now you oil and manipulate the large gear wheel until it comes loose and you can see the blades move back and forth. Put the whole thing back together and you are ready to go!
Jun 12, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Need an online parts catalog to replace handle
This is actually a 2.6A Hedgehog 22" B&D: I found an excellent website at toolpartsdirect.com with an exploded diagram and easy ordering of the parts required.
Jun 04, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012 Logo
652 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
