Question about Microsoft Xbox 360 Console
Picture freeze with lines horz. - Microsoft Xbox 360 Console
  • 767 Answers
Check to see if other clean /new games freeze , and just
before it happens do you get a popping tone? If so Its the G.P.U.is
coming un-soldered from the main board. MS does not repair
this type of failure properly. The Unit Needs to have a Proper
X clamp mod on both the G.P.U -C.P.U .and that take care
of 99.99% of the problems . no kidding
Posted on Jul 14, 2009
  • 296 Answers
Clean the contacts where the A/V cable connects to the back. If it still freeze then it would be hardware problem with the video card. Unless the disk is scratched bad and it creates a skip that will freeze the picture
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
Very wide pink and green horz lines, no picture
CLEAN Y SCAN RIBBON CABLES WITH CONTACT CLEANER AND COMPRESSED AIR IF THEY DONT DISAPERR REPLAC Y SCAN BOARDS
Apr 25, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Red key located on screen only here the sound
If you have sound and no picture,do you have on screen graphics? If no you have lost High voltage and have no horz. or vert. deflection possible power supply problem needs to be repaired by qualified Technician. If you have on screen graphics you may have a problem with the input you are usng,TV,VCR or LINE
Apr 11, 2010 | Apex Digital GT2025DVR 20 in. TV/VCR/DVD...
Hi, Two sets of lines have appeared on the screen
are these lines vetical or horz if they are vertical your panel has failed and will need to be replaced big bucks if they are horz , then it could just be the T-con board and you will need a tech to confirm this I have seen this problem cause by a poorly seated connection
Dec 07, 2009 | Televison & Video
I have a good picture then it goes horz. with static and then a good picture and then a horz. lines and static about every sec.
The horizontal line indicates failure of vertical section, checkout the output capacitor of vertical-section connecting to the yoke (vertical) for any loose contact, dry solder, capacitor wear-out.
Need to check the register and filter capacitor that powers the vertical-section.
Sep 28, 2009 | Sanyo DS25390 TV
I try to vibration pcb but samething problem on many horz line on picture.
Please intimate exact model and brand of your TV that you are looking for info.
Thanks.
Jul 19, 2009 | Samsung DLP HL-P5663W 56" TV
One side of blurryness
now one thing at a time. the picture that is blurr does it have red or blue lines on the rt or lt side it sounds like the convergence is out on the unit and that will cause the picture to be blurry. and is the big screen in warranty please let me know marty
Oct 09, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Picture on TV showed as small lines at the top of the screen. Sound was fine but picture was bad. This happened while playing a video game. Unplugged TV from the outlet for about a half hour. Plugged it...
I would definitely say you have a heating up problem, im guessing either the convergance ic are heating up or HOT or horz output or a capacitor, you could try spraying freeze (radio shack carries it) when the problems starts showing up to isolate the problem.
Dec 21, 2007 | RCA P46921 46" Rear Projection Television
Diagonal lines across picture
do you have a dvd or vcr hooked up to this? Is it hooked up with the a/v cables (yellow, red and white). double check the cable hookup make sure audio cord is not in the video jack, from what you are saying this will do that if it is. Also there is a capacitor on the main board believe it to be C3412 which intermittenly gives horz. lines but haven't had a audio tone with that.
Nov 29, 2007 | Zenith B25A76R 25" TV
D40W20
Part of your feedback voltages are now incorrect. Find the solder bridge and remove it then see if you at least get back where you were...accordianman
Oct 16, 2007 | RCA Scenium D40W20 40" Rear Projection...
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
