Question about Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac
How do I clean the fuel line on troy bilt 5hp chipper vac?
I've changed the spark plug, new gas, checked the oil, doesn't start.
Troy Bilt Chipper Vac about 20 years old, hasn't been started in 2 years. Thanks for your help.
    President:
  • 1,129 Answers
Unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
I have a troy built chipper vac that starts but won't stay running it has gas and new spark plug
How old is the fuel in the tank and also look into the tank for water from condensation. If the gas is older than 2 months drain the tank and the carb bowel.
Nov 06, 2015 | Troy Heavy Machinery
Engine will not fire or try to start on my Troy-Bilt Super Tomahawk 2 in 1 Chipper/Shredder, 8 h.p., Tecumseh engine. Getting good spark; changed to new gas; no air blockages found.
If your getting spark no doubt its a fuel problem. Does the inside of the cylinder look wet when you removed the plug. The seals in carb go bad all the time. You need a rebuild kit most likely. Very cheap an easy to do. If its a bowl carb it should be done. Should solve your problem. Starting problems are no spark or no fuel. Carb leak an seal get weaker all the time. Gas the way its made today eats the seals away.
Mar 05, 2014 | Troy-Bilt Heavy Machinery
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Have a troy bilt model # 47282 hard to start what could it be
is the gas any good?is it newer than 30 days old gas is only good for 30 days in small engines
Apr 24, 2012 | Troy-Bilt Chipper Shredder
I have a Troy-Built Chipper/Vac Model 47279 (5HP) that has not been run in a while. I have drained the fuel and added new but it will not start. The old fuel did not have any fuel additive prior to storage...
i have the same Chipper, vac. Have you checked for spark? You may want to clean the fly wheel. I use emery cloth to clean the area at the magneto, If there is no spark, Also you may have to clean the carb. I have been looking for a manual for this model with no luck. Hope this helps!
Jul 30, 2011 | Troy-Bilt 24" SelfPropelled Chipper...
I have Chipper/Shredder model 47321, 10 HP. I have
try changing spark plug, if unit sits outside rain can rust the coil but I would try a new spark plug first and make sure it;s gaped correctly
Oct 03, 2009 | Troy-Bilt Chipper Shredder
Troy Bilt Chipper/Vac 47282
There is a blockage in the outlet from the fuel tank, there is a filter in the tank and it is dirty. Try it anyway. Stephen.
Sep 21, 2009 | Troy-Bilt Chipper Shredder
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Won't start
check the fuel line it could be pluged up. never leave gas in any thing when you put it up for the winter.
Jan 04, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac Logo
763 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
