Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Getting grey transparent rectangular box on screen
Just moved, added direct tv satellite, now getting a grey transparent box on screen that comes and goes as i hcange channels
Check caption settings.. it might be set to "text".. try setting it to off
Posted on Aug 03, 2009
There is no picture on tv
1.is the tv plugged in & getting electric?
2. Does the tv show a raster,a blue screen.
3.is the tv getting an input signal , assuming that the answer to 1 &2 was yes.
4. Is your cable box plugged in.
5. are all the connections into your cable box connected
or did one fall of
6. did you pay your cable bill on time.
If your cable box is bad , the cable company should fix or replace it for free. If you or someone else unhooked the connections,say by tripping over them,the cable company will restore the connections and chatge you a service call fee.
7. do you have dish or direct tv? either of those services will loose picture if it is raining out and picture wont come back until after the storm passes.
8. if you have dish or direct tv, and a branch,a person or an animal, a bird, has fallen on the dish/direct tv antenna, it may have misalligned the dish and it will no longer recieve the satalite signal. THere is a reallignment service
available;dish network charges $95.00 unelse you have insurance,like i do,so it only cost me $15.00 I never had direct tv soi could not say, but dish net claims direct tv is more expensive
You can allign the antenna yourself ,if it is not on a steep roof. You need one person moving the antenna & another person at the tv telling him if the picture is getting better or worse. The dish box comes with a built in signal strength gague for that purpose.
enjoy considering these options and they next time you ask
please enclose all the information that you can so that we have something to go on and work with.
Oct 08, 2013 | Televison & Video
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Black rectangular box on screen from doing menu
Take ur tv remote go to menu check the captioning functions turn all CC1,2,3 off and all txt off too.Yes,text functions is on,that why u getting a big black block flashing on ur screen.
Mar 28, 2010 | JVC AV-32D305 32" TV
I have a mitsubishi HD1080 Ser.#Wf65809 It has worked fine until this week when DirectTV hooked-up their satellite dish and programmed the tv. When the tv is turned-on e the picture is great for about 6-7...
It may be an internal filter on the tuner board or in the cable line. Otherwise it may be a firmware problem that is causing this. Make sure tv is set for CABLE and not AIR
Sep 09, 2009 | Televison & Video
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
Connecting to Direct TV satellite box
If the cable is connected to Antenna/cable port on your TV, then set the TV to antenna mode and search for programs after which you should have some stations showing.
Jan 16, 2018 | Sanyo DS24425 24" TV
Problem while printing rectangular boxes
check your printing program. are you using a mac or apple program? like quark? check setup, maybe there's something like reverse printing option or transparent printing.
Sep 11, 2007 | HP DesignJet 500ps (42 in.) InkJet Printer
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
