Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Canon SD800 will not turn on.
My Canon SD800 will not turn on. From various posts, I've heard that a possible problem could that there is dust/sand/grit stuck in the lens. Any suggestions?
    Problem Solver:
  • 12 Answers
If youve had it under a year you can try sending it back for warranty and see if they can fix it. However their warranty service sucks if its not actually something wrong with the camera. Maybe try and find a local store that fixes cameras and see if they can clean it out?
Posted on Jul 14, 2009
My PowerShote SD800IS lens will not retract and makes a grinding noise. Please help!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 15, 2011 | Canon PowerShot SD800 IS / IXUS 850 IS...
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
My lense has stuck out and wont come in again, like it should wen the power is off, the camera is otherwise in perfect condition after 18 months never dropped etc, not a scratch on it, i dont want to buy a...
The len's on these are very suseptable to any dirt, dust, sand, and grit, one little grain in the gears and stuck, I just cleaned two, one was OK, the other was beyond repair, it can be just dust from tossing it in a purse or pocket, it gets in between the case and lens, use a dust proof bag or case, the ones that come with them are open and terrible, toss up, what costs more, having it repaired or buy new, or buy different sealed type, which they are coming out with, I heard of a life-proof camera, sounds like what we need. Or upgrade to a higher end camera, they are better, Hope this helps.
Apr 27, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Was shooting with Canon PowerShot S3 IS and the lens won't retract,screen says lens error,restart camera. I have restarted camera, changed batteries etc... still nothing. You can hear a clicking sound like...
The lens mechanism had probably got some dust, sand or grit jamming it and stopping it from retracting. Sadly the lens will be difficult to repair yourself as it needs to be completly stripped from the camera. Find a good repair shop and get a quote locally.
Feb 08, 2010 | Canon PowerShot S3 IS Digital Camera
When i turn on camera it says "lens error, restart camera". And the lens won't go back all the way in.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon SD100 Lens Error (camera)
First try calling 1-800-OK-CANON to see if warranty repair applies. If not...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 12, 2009 | Canon PowerShot SD1100 IS Digital Camera
My Canon Powershot SD800 IS, has had its lens stuck as if it were zooming out.
Jun 10, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have a canon powershot sd800 IS and the  lens appears not to want to close! The camera is just over a year old and rarely used!
Jan 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Dirt jammed in lens barrel area
Hello Dear,
Both of you are required to take your camera to a Canon Care Centre or an expert and get the camera cleaned thoroughly, once all the dirt is removed the camera will work fine but this is not possible at your place.
Wrm Regards,
Manoj Joseph
+91 9352008418
Feb 16, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
429 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
