Question about Whirlpool Calypso GVW9959K Top Load Washer
Can I find a picture of what the top inside is whirlpool calypso
Whirlpool calypso HB50600G7 can I find a picture of what the top inside is supposed to look like i have a loose blue wireon the circuit board
  • 525 Answers
Go to www.repairclinic.com, for a detailed part-by-part breakdown, with pictures.
You could also find other sites by going to: www.homemanagement.services.officelive.com, go to the site map and select "appliance repair help"
Posted on Jul 14, 2009
Where do you locate the model number on a whirlpool calypso?
The model number on Whirlpool manufactured top loaders is usually printed on a nameplate along the wash tub rim under the lid.
May 26, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
How do you open the top of a whirlpool calypso
You need to use a putty knife. It should slide under the "controls" and hit a spring latch. Push hard, it's not easy. The latches are on the outsides of the top.
Jan 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso top loading washing machine displays a LF (long fill) error code
I would check the water inlet valve first. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad solenoid and the inlet valve assy will need replaced. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Oct 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine shows LD even when water pump was replaced
dccvan,
OK, now that you have a new pump, look at the back ouf the unit. You will have to take off the back cover. On the back of the tub you can see where the 'check balls' are for draining & recirculation. Here's a picture: click here. It might be a little difficult to see through the plastic, but check to see if there is anything stuck inside there near the check balls. If so, you have to take the pump hoses off at the tub connections. You can use mechanical finger grabbers to get stuff out. Check this picture also: click here. If you take the hoses off, check them for debris inside. Check your drain hose to the house drain also, could be something in that hose too. Flex shaft mechanical fingers look like this: click here. you can get them at just about any autoparts store.
Hope this helps,
-samson39
Jul 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso top load washing machine. No warning... no power. no breakers tripped! Outlest tested fine with another appliance.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Topload washer Won't aggitate correctly
Possibly a belt issue take the top cover off of the agitator and remove the bolt that holds it down. There will be gears inside if any of these parts are broken this will also cause it not to agitate. Let me know
Jan 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Do you know the button sequence on a WHIRLPOOL CALYPSO which would check the washing, rinsing, spinning and draining cycles quickly? Saw a repair tech do it once.
if you remove the "emblem" from the front of the machine(very front edge of maintop assy.justs prys rigth off) behind it you will find a screw 1/4 inch socket. after removing hte screw the main top will pull foward slightly andthen lift backwards, under there glued to the inside front panle youll find a tech manual with all hte info on all testing procedures,uncliding hte "key dance" to get into different modes"
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Repair manual
Somebody stated in a consumer product review that he found a repair manual mounted inside the front panel of the machine. He also gives some details of repair work that he did to his washer, so you may want to read the review for yourself. Link below: --> http://www.dealtime.com/xPR-Whirlpool-GVW9959K~RD-380361477764
Aug 04, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
