Question about Amana ABD2233DES Bottom Freezer Refrigerator
Water dispenser does not work
The water dispenser does not work. when I push the button I hear the pump running, but no water comes out. I changed the filter, and it worked. I ran the water for about two minutes to flush the carbon out as per the filter directions. The next morning I went to get a glass of water, and same problem. Push the button, the pump runs, but no water comes out. What's the deal?
  • 55 Answers
Check the flow on plastic pipes
Posted on Nov 18, 2007
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
My side by side Amana water dispenser no longer
you have a kink in your tubing test by checking at pump which is visable by taking back felt cover at bottom where water tube goes in cut a few inches away from pump to see if water flows when you activate swich if so you have a kink in your system to repair the cut they have couplings in the store
Mar 22, 2010 | Amana Refrigerators
Water dispenser stopped working, freezer temp down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Dec 17, 2009 | Amana Side by Side 20.6 cu. ft. Cabinet...
No water is coming out of the dispenser, but the ice maker seems to work. I have already changed the filter and checked for air trapped in the line. Any ideas?
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 23, 2009 | Refrigerators
Samsung RS253BABB. Where is the water pump??? I press the switch for the water dispenser and I can hear the pump running but no water comes out. The ice maker works so its getting water to the unit through...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 21, 2009 | Samsung SRS20DTD Side by Side Refrigerator
No water comes out of dispenser of my kenmore side by side ice maker works great. what can i do without geting a repairman
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out
Aug 18, 2009 | Refrigerators
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
Ice maker works, water will not dispense
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
OR
Jul 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
The lines are likely clogged and will need to be removed and cleaned. Otherwise, although the pump starts, the valve may be clogged or non-functional.
Feb 11, 2018 | KitchenAid KSSS36QK Side by Side...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Amana ABD2233DES Bottom Freezer Refrigerator Logo
198 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
