Question about Canon PowerShot A510 Digital Camera
My PowerShot A510 will not retain the date and time. Everytime you power the camera on you have to re-enter the date and time. I have replaced the lithiam Coin Battery twice and that does not help. Any suggestions.
  • pam_juhr Jul 15, 2009
    Yes I am entering OK and the date stayes as long as the camera is on but once you turn off the camera and turn it back on you must reset again.
KingDWS
  • 1606 Answers
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
Posted on Sep 12, 2009
  • 3 Answers
SOURCE: date and time
When you open the battery compartment, there is a small round battery(under the cr1220) slot, lift up this slot and take the battery out and replace it, this is the battery for that function of the camera.
Posted on Dec 28, 2008
old marine
  • 2036 Answers
SOURCE: Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
Posted on May 08, 2008
SOURCE: lens cap stuck
I was messing around with this today, ended up where it seemed in was working.
Power up, let lens out, then take out batteries. Pry off silver band patiently using fingernails. Then pry off overlying black plastic piece. There are four units underneath, pay attention to how these are put on, mine popped off, but it wasn't too hard to figure out how to put back together. There are pins and holes and kind of fits like a jigsaw. Once off clean with alcohol where you can.
Put batteries back in and open and close a few times. This will help understand movement where pins of lens cover pieces go. When putting these back on make sure camera is in off position.
The lens cover pieces need to be put on so that the pin portion has some resistance. Move one so that it drops in then push up to get other in place. Let them come together and hold these in place.
The two smaller pieces will close the cover. Put the hole of the closer piece over the pin. Then move slightly so you can retract spring with a small instrument and subsequently engages pin on closer. Place top black piece back on, then silver.
This worked for me, hope it does you also! Good luck.
Posted on Mar 16, 2009
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A510 black screen when taking photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jun 20, 2009
Date and time won't stay set
Had the same problem. The problem is a small button cell that needs to be replaced. From Canon's support page:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510?CMD=MIXED_SEARCH&mName=PowerShot+A510&mType=PowerShot+A+Series&pageKeyCode=ekbresults&searchString=date+and+time+wont+stay&BASIC_SEARCH_CURRENT_TOPIC_ID=1236&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
Jul 13, 2012 | Canon PowerShot A510 Digital Camera
Canon Powershot A510 will not remember the date setting. I have replaced the date battery, and still no luck. Any ideas?
If you look inside the clock battery slot, you'll see two contact points where the battery makes contact. They should be bright and shiny. If you notice any discoloration or corrosion, consider trying to clean with a nail file or emory board (or whatever you feel might remove that corrosion). Also, consider placing a small piece of cardboard directly under the battery in its holder to raise it up a bit, possibly improving contact with the upper connector. Good luck!
Jul 04, 2011 | Canon PowerShot A510 Digital Camera
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
Camera keeps forgetting the date.
This can be because the camera system battery usually a CR2030 needs replacement. Check in the manual where it is located
May 29, 2008 | Canon PowerShot A510 Digital Camera
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Having to reset date and time
Solution: Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution_a70.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids could damage the stomach or intestinal wall.
  1. Confirm that the camera is turned off.
  2. Open the terminal cover and use your finger nail to pull out the battery holder.
  3. Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
  4. Insert a new battery with the ( ) side facing up.
  5. Replace the battery holder back and close the terminal cover.
  6. When the Date/Time menu appears, set the date and time.
note_icon_a70.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your country.
Dec 24, 2007 | Canon PowerShot A520 Digital Camera
Setting the date and time
No need to remove part of the camera case. This camera (Power Shot A510) does have a backup battery that is easy to get to. Under the rubber flap where you connect the cable, there's a little door you can pull out with your fingernail. There is a CR1220 battery - can be found at any jewelry store, as it is a watch battery. I replaced that and viola! No more messing with the date/time every time it powers off/on!
Dec 02, 2007 | Canon PowerShot S30 Digital Camera
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Date and time reset at power-on
Canon point and shoot cameras have an internal backup battery (a very small watch battery sized cell). Look under your battery door - do you see a small tab that has "CR1220" or something like that marked on it? If so - this is your backup cell. Just replace it and you will be good to go. If you do not see this, then the backup battery is buried deep inside the camera and would require full disassembly to replace. David Millier Advance Camera Repair
Feb 18, 2007 | Canon PowerShot A510 Digital Camera
Canon PowerShot A510 Digital Camera Logo
328 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
