Question about Whirlpool LGB6300 Gas Dryer
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do anything anyways. What part really needs replacing, the ignitor, the coils, or something completely different?
  • Whirlpool Master
  • 1,606 Answers
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Posted on Jul 19, 2009
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
  • 142 Answers
SOURCE: I have a Whirlpool Gold
The first thing you need to check is if you actually have 240 Volts going into the dryer. Sometimes one half of the (dual) circuit breaker opens and only sends 120 Volts down the line. If you hear a buzzing sound when you press "start" but nothing happens, it could be a stuck motor. Or the motor could be running but the belt is broke. There are more possible scenarios, but try this first.
Posted on Jun 08, 2011
heatman101
  • 43501 Answers
SOURCE: My whirlpool ultimate care II electric dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 12, 2011
  • 314 Answers
SOURCE: I have a Whirlpool Gold Ultimate Care II Gas Dryer
you have the replace the coil valve part no. # 279834 the coil is located just on top of the gas burner
Posted on Sep 07, 2011
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    I have a Whirlpool ultimate 2 gas dryer Model #LGQ2285JQ1 When I view the igniter through the peep hole I see the glow and see the gas igniites.It lights quietly. However the gas turns off after just 5...
    Hello, welcome to FixYa.
    I'll start by saying your post indicates it is obviously a Whirlpool gas dryer. If this is a symptom were the ignitor does glow yet it won't ignite, or as you stated ignites for a short time before going out and not cycling back on...I would be looking at the burner coils.
    Once you've gain access to the coils you'll need to remove the wire harness and check the continuity.
    Here's the tricky part though...many times they will ohm out ok when cool (not operating) yet as soon as there is current passing through the coil it "opens".
    The wire inside the coils is so fine that often it only takes a small current to "open" the circuit...thus not igniting the 2nd, 3rd time and so on. Most times it will only be one coil that fails but it is good practice to replace them both, many places used to sell them in a kit so double check with your supplier.
    I've attached a link here, though it may be different than your model the principles to changing the coils are the same. As far as what part you may need and how to get it. There are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
    Kit contains both the two wire and three wire solenoids. One solenoid is the primary and one is the safety. Both have to operate for the gas valve to open. Usually, one of them burns out as I said but you should always replace them as a set.
    **Please turn off the gas and unplug the dryer before performing any service...safety first**
    The most common for Whirlpool (Maytag too) is part number 3479 at "repairclinic" as this link should provide you.
    http://www.repairclinic.com/PartDetail/Gas-Valve-Solenoid-Set/3479
    Let me know how you make out or if you require further assistance and I'll do whatever I can. Good luck.
    Regards,
    Macmarkus :)
    Oct 23, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    heatman101
    Jul 21, 2011 | Whirlpool Dryers
    My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
    it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
    Dec 13, 2009 | LG DLG2524 Gas Dryer
    Whirlpool gold ultimate care II dryer shuts off then won't start for a while.
    I am assuming this is a gas dryer and it gets hot to start then gas goes off? if so this is a problem with the saftey valve coils, this website will instruct you how to replace them.
    http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/gascoil.php
    Jun 22, 2009 | Whirlpool GGQ8831L Gas Dryer
    I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
    first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
    May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
    Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
    Hello gigiknoll
    Welcome to Fixya
    My name is Huum,
    This model should be electronic ignition and does not use a pilot light.
    The igniter may be faulty.or the gas module may be faulty.
    Pilots are a thing of the past!
    This requires a tech to test it with equipment.
    Thank You For trusting us with your question
    Please remember to leave a solved rating before you leave!
    Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool LGB6300 Gas Dryer Logo
    579 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
