Question about Dual XDV8125
Can anyone tell me what the wiring pin out is ?
Can anyone tell me what the wiring pin out is on the power cable for my xdv8125. i need to make a cable for it, it was stolen and returned but that cable was missing.
looking at the connector side with the lock clip up there are 2 larger pin sockets then 2 rows of 7 smaller pin sockets.
i know the 2 big sockets are power and ground but i need to know what the other 14 are and there location.
can some one help me?
  • 655 Answers
Hello daneggan,
I'd recommend getting a new plug-in harness either from the manufacturer or from an aftermarket source.
Installer.com sells harnesses for most brands. And if you give them your vehicle make and model, they'll solder two harnesses together and make you a custom plug-in solution. The cost is only $7.50 to connect the harnesses, about half the cost of a soldering iron and heat shrink or a pack of good inline crimps and crimping tool.
Hope this helps.
Posted on Jul 14, 2009
Pin out for HP Q3110-60009
This is a simple cable, connector for 2 pin power supply, connector for USB 2.0, and male six pin round cable (same as PS/2 Keyboard/Mouse.) I have the scanner and power supply.
tia
Mar 30, 2012 | HP ScanJet 4600 Flatbed Scanner
Atx motherboard wiring diagram
For the power cables from the Power Supply? Or Power Supply, and Front Panel header on the motherboard?
For both of these you need to state the computer manufacturer name, and Model Number.
Post back in a Comment.
If you just wish a generic, one-size-fits-all explanation;
A) 20 or 24-pin ATX main power cable.
The older computers use a 20-pin ATX main power cable. As computers needed more power to the motherboard, the 24-pin ATX main power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll the page down for info on the 24-pin ATX main power cable.
[ Much older motherboards (AT) used two main power cables. { In the link - Original PC main power cables} ]
B) 4-pin ATX +12 Volt power cable.
Was brought out because Processors needed more power, than the 24-pin ATX main power cable feeding the motherboard, could deliver.
Power for the Processor,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) 4-pin standard Peripheral power cable
Commonly misnomered as 'Molex'.
Molex was a model name given by the first manufacturer, of this design of power cable connector.
The name stuck. Kind of like referring to an adjustable open-end wrench as a Crescent wrench.
It is also referred to as a 4-pin Standard Peripheral power cable, because there are two styles of 4-pin Peripheral power cables.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Generally used for IDE (PATA) harddrives, and IDE optical drives.
4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Older computers used it for power to the Floppy Drive. It's generally used now to provide power for a Card Reader.
Note that both types of connectors use the same power wires, and 2 ground wires.
Yellow is 12 Volts
Red is 5 Volts
Black is Ground
[ Also, in the ATX main power cable:
Orange is 3.3 Volts, the Green wire is the Soft Power On wire. Abbreviated as PS_ON.
Power Supply plugged into power, the Soft Power On wire is briefly touched to ANY Ground wire. This is bypassing the Power On switch.
If the computer (Power Supply) comes on, you have a bad Power On switch.
IF the computer (Power Supply) does NOT come on, you have a bad Power Supply ]
(ALL Black wires are Ground wires. They all lead back to one central Ground point.
ALL power wires lead back to one point in the power supply, for EACH power wire.
The 12 Volt power wires, (Yellow), all lead back to one point in the Power Supply.
This is the 12 Volt power rail.
The 5 Volt power wires, (Red), all lead back to one point in the Power Supply.
This is the 5 Volt power rail.
The 3.3 Volt power wires, (Orange), all lead back to one point in the Power Supply.
This is the 3.3 Volt power rail ]
D) SATA power cable
15-pin power cable for SATA harddrives, and SATA optical drives,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ The smaller 7-pin SATA connector is the interface cable, or data cable.
IF, you have a SATA harddrive that has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
It will burn out the harddrive if you use both. It may not do it right away, but eventually it will.
I have had people state over the years, that they were using both power cables. Came back two months later to tell me their harddrives had burned out ]
More to follow in a Comment.
Regards,
joecoolvette
Sep 30, 2011 | Computers & Internet
All my wires in my monitor r unhooked where they go can you tell me.
If your wires are unhooked, Usually new monitors wires are colour coded , for example, blue to blue, yellow to yellow etc.
If your wires are not colour coded, There is only one way the wires can go, They won't fit just anywhere. If they fit into one connector, then that will be where it needs to go.
Hope this helps
Mar 13, 2011 | E-Machines T2642 PC Desktop
I have the dual xdv8125 car stereo and i hook all the wires up but nothn comes on. its hooked upto a 12volt dc power converter box. it wont do nothing at all.
Make sure that the DC has more than 3/5Amps rating with good DC to make the set working. Test with a car battery to confirm your connection if not check the speaker connections, the main power, switched power and ground must be in order.
Aug 28, 2010 | Dual XDV8125
I need a manual for my XDV8135
CLICK HERE
I just answered this for someone else too ;)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Dual XDV8125
Dual XDV8125 car stereo wiring
CLICK HERE for a copy of your owners manual - install diagram is on page 5
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
Motherboard Pinout - Please Help
here are some sites that may help you.
all these should be marked power switch may say pw,prs,ps, power led may say pld, pl,led, hhd say hd, reset switch maysay rs, set, these connection will be grouped together, and pin layout 1 red or hot wire, or the main wire for the device you are trying to operate.
www.motherboards.org
www.tomshardware.com
www.twinight.org/chipdir/
www.anandtech.com
the connections to the back plate is standard the amount of pins match up the cable, the number 1 pin will be marked some how and or the cable will only be able to plug in one way.
with an exception if you are using serial connector and we hardly use them. the rules are the same as above, and plug ins maybe one way also.
the ribbon type will have a marking on the cable or ribbin line or dots or hasshs marks that is pin #1
match with pin out on motherboard pin1 or pin 0,
rod
Feb 11, 2009 | Syntax SVM266A (SYSVM266A) Motherboard
Pioneer cdx-p24s wiring
**** - have you had an answer yet?
I've got one of those too - let me know if you still need the info.
Grtz,
Rick
Oct 06, 2007 | Car Audio & Video
Dual XDV8125 Logo
214 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
