Question about Numark DM1200 DJ Mixer
Numark dxm power failure?
I have a numark dxm 09 when i switch the power on i get only 1 light that comes on for about a second then switches off then it seems to lose power
I'm having the same problem, just wondeered if you found any solutions to this?
Posted on Dec 03, 2009
Numark C3usb - how to replace a fuse
Trace the inout power wiring. You will find a fuse someplace very near where the power comes in. Note that they MAY be one of several types that don't look like common glass fuses. ALSO a common thing is that the fuse is in a little "boat" that is right adjacent to where a standard line cord like on tower PC's use. This boat has to be pried out to get at the small fuse in it. Choose the right size fuse for the 230 v operation.
Mar 04, 2013 | Numark Industries Numark C3usb Rack Mount...
Distortion troubles with numark ndx400's
The bad news is it could be any of them. or it could be the lighting- CFL's and regular flourescent lighting are bad for audio, as are switching supplies used in TV's, microwave ovens and some musical gear. They are worse than lighting dimmers for noise.
The thing to do is start at the speaker itself and work through the chain of devices to find the one distorting. An old transistor radio is useful here. Most actually do have enough power to faintly drive a large speaker- listen for scraping and rattling- it would mean the voice coil windings may have come loose or the coil form is damaged from heat.
Move back to the amp input and try again- this time listen for a clipped sound if the speaker checked out okay. It would sound like the Charlie Brown adults in the cartoons. That would be a failure of an active component in the amp. If you now hear rattling or scraping- the speaker voice coil is bad and should be repaired or replaced.
If it sounds good, move back to each deck. apply your radio- volume turned down to an input it one is provided. Each should sound clean like the amp did. If no sound or distorted sound is found here- which is the most probable location, it is likely one of the IC chips is at fault. Likely a 4558 if an IC fault, otherwise suspect dirt or hair on the encoder connected to the spin platters.
Mar 30, 2012 | Numark Industries Numark NDX400 Tabletop...
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
Kmx02 wont turn on
Make sure the plug for the power cord is the same polarity and DC or AC for the mixer. Also make sure the inner diameter is correct for the station power jack as well.
As long as power from the supply is correct and adequate, theother potential sources of problems can be a blown internal fuse, broken power jack circuit tracks/traces, bad solder joints, dirty switch contacts, some contact cleaner sprayed in the gap of the switch toggle and then flipped rapidly for a number of times might clean it up.
Feb 04, 2012 | Numark Industries Numark KMX02 Dual Deck...
Do you have a FAQ section, just so that I can review what others have experienced. I have 2 Mix3's using powered JBL speakers without any problems. But I am thinking of switching out the powered...
No problems doing this. Just make sure to power the amp and the Mix 3 from the same receptacle or power conditioner. Remember IF you are using the EQ functions of powered speakers you will NOT have those when going directely to an amp.
May 08, 2011 | Numark Industries Numark CD Mix 3
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
Aug 10, 2009 | Numark DM1200 DJ Mixer
Fender Hot Rod Deville 212 - popped and died
This may sound stupid, but did you check the fuse?
Apr 22, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Numark DM1200 DJ Mixer Logo
222 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
rhodesworks
Are you a Numark Music Expert? Answer questions, earn points and help others
