Question about Kramer 903 2-Channel Amplifier
Replacement for Kramer 903 wall wart
Is there any vendor that will sell me a replacement wall wart (120 VAC in, 12 VDC @2.0 amps out) for my Kramer 903?
  • 54 Answers
Try mcm electronics.
Posted on Dec 01, 2007
I'm attempting to connect my new axiom pro 61 via Midi cables to my mbox2. To do this I understand I must rely on the power supply rather than USB. When plugging the axiom in to the wall it will not turn...
The AXIOM SHOULD turn on with just the wall wart adapter so you HAVE A PROBLEM.
First thing is to check the adapter that it is the correct one. It should be a 12 VDC 1 amp unit with positive center pin output.
Common adapters for pedals WILL NOT WORK.
Assuming you have the correct adapter, VERIFY the connector is plugged fully in the AXIOM.
Feb 09, 2011 | M-Audio Axiom Pro 61 USB Keyboard + Sp2...
The spring whch controls the on/off function of my wall timer has broken. Who sells a replacement?
E1010 and E1020 parts are not sold.
I research and test timers, and do not know any site selling parts for in-wall timers of any brand.
Dec 28, 2010 | Intermatic Timer E1020, Single pole/single...
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Nov 10, 2010 | Vacuums
Generac 5500XL, model#09778-7 no output. Changed the power regulator board. No luck. Flashed the 120 plug with 12-30vdc from DC board. Nothing. Excited the brushes directly with DC board. Only got 2.36VDC...
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
Jan 22, 2010 | Coleman Powermate 5000W Home Backup...
How do i excite a coleman sport 1850 generator?
This unit is capacitor excited, simply pull the terminals from the capacitor and apply 12vdc to the the wires for about 1 second. Then plug capacitor back in reassemble and run generator and check voltages. If the rotor magnetism has been restored and everything else is good you should be producing power now.
There is an alternative way to excite back end but it is a little more dangerous. It involves starting the unit and then applying 12 vdc to either of the 120v outlets for less than a second. This is the best way but it is more dangerous because once the back end is excited the outlet will now be putting out 120 vac. So if you leave your 12 vdc source connected too long you will back feed that source with 120vac. What we've learned to do is to have 2 wires coming out of the outlets with the tips exposed then we take our wires with the 12 vdc source and just brush them quickly against the 2 wires coming out of the outlet.
Nov 05, 2009 | Coleman Sport 1850 Generator
Tips how 2 wind transformer ac -dc .output 12volts. in put 240
your windings of primary to secondary must be in a ratio of 20:1. That is, for a primary with say, 100 windings and input 240 VAC, 5 secondary windings will give you 12 VAC. you need to rectify then regulate if you want 12VDC. Just buy an off the shelf wall-wart.
Jul 13, 2009 | Bose Lifestyle 18 System
My ac adapter seems to have gone bad on my CLT1554 model lcd tv. can I find a replacement?
check the adaptor it will say like 120 ac to 12dv at 1000 ma this what your looking for or go to the back side of the tv like mine says 12 to 18 vDC I think as mine I could run on my car Battery, but power supplys are UL most likley rtatyed and have the specs on the in today tech world power supplied TV or 12 DC and laptops 18-21 vDC when the use LCD technoligy......1000ma =1 amp
Jul 03, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Refrigerator totally inop. 120 VAC & 12 VDC present. Unit is model # RM3662.
Using one of the two power supplies is there any running sound. It is important that the van is not blocked by lint. The fan is easy to stall with spider webs and dirt. good luck
May 23, 2009 | Dometic RM2852 Refrigerator
Fuse missing
I would start with a 1.5 AMP fuse (175 watts / 12 VDC = 1.6 amp)
Make sure the fuse is rated for at least 120 VAC. Hope this helps!..Gary
Mar 10, 2009 | Dell 175 Watt Power Inverter Car Adapter...
Kramer 903 2-Channel Amplifier Logo
118 people viewed this question
Top Kramer Audio Players & Recorders Experts
Are you a Kramer Audio Player and Recorder Expert? Answer questions, earn points and help others
