Question about Pool & Spa
I have 3 wires how do I wire the Wayne Reliant one swimming pool pump?
  • 990 Answers
You should have a wire diagrahm on the back of the motor. It will give you placement for your lines and how to wire it for 110v and 220v. In ether case two of the wires will go to the line connections. You should have one green wire that will connect to the motor caseing on a green screw. It will be out of the way and not on the wire board. It will be on the motor housing off to the side. I hope this helps.
Posted on Dec 19, 2009
Wire for 110
see side of motor it should show low voltage vs high voltage have to move wires
May 31, 2013 | Waterway Inground Pool Pump Champion No....
Wayne WAPC250 1/4 Auto On/Off Pool Cover Water Removal Pump
good pump its a rule by the way a lot of times the automatic goes bad cause the hoses frezes and the pump goes bad
Apr 07, 2013 | Rule H53sp 24mgra Swimming Pool Cover Pump...
How do I connect the red and black wires (power source) to the SP2610x15 pool pump?
Your line leads go on the L1 and L2 terminals in the rear of the motor. It will not matter which wire is on which terminal as long as you seperate them with only one wire on either terminal.
John
May 01, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Need to know which wire goes on the L1 terminal on a Hayward Super Pump 1 hp
The black wire would go on the L1 terminal..that is the "hot" wire ...
heatman101
Aug 04, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward Swimming PoPump is 4 years old - when I opened pool, pump
it you've inspected all the wiring for possible shorts, the most likely problem is that the motor has developed a short in the windings. You may have to replace the motor. First check for loose connections and make sure the wiring going to the pump is good. Also, check the start capacitor, should be under the hump or under the end cover on the motor. If it's bloated or leaking, it's bad.
Most likely the winding have a direct short.
Apr 05, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Have a supreme Solar - Solar conroller for swimming pool. Roof indicator light is flashing and system wont turn on, (not even in manual mode) Pump working OK though. What does this mean
it sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
Nov 08, 2009 | Solar Heating System For Swimming Pools
Pool & Spa Logo
281 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
