2005 Volvo S40 2.4 Logo
A
Anonymous Posted on Dec 06, 2015
Drivers power seat wont move forward. Can't push clutch if I can't move the seat forward
I have tried the electric lever, no seat bar to pull. Cannot locate where fuse would be. I need to be able to drive but cannot as I can't get the seat to move forward to a comfortable position. Manual trans vehicle.
Biggie Neumann
Level 2:
Habit-Forming:
New Friend:
  • Expert 75 Answers
  • Posted on Dec 06, 2015
Biggie Neumann
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
75
Questions
12
Helped
20829
Points
300
Check the two fuse boxes (use your smartphone camera and flash) for anything burned out . Note: There are two fuse boxes, one inside, under the dash and another by the engine.
Owners manual will help you locate the seat power fuse.
2answers
Drivers seat on Peogeot 307 wont slide forward or back, when you pull the bar at the front one side releases but not the other, it stuck fast...need help..how do I free it off?
the lever activates cables to either side of the seat runners
one side has broken or come off
reach under the seat (from the back gives the most space and replace or re-clip that cable to the bar
My front drivers side seat wont move forward or backwards. seat stuck close to steering wheel
need to check under the seat or even remove the seat if you cant see the problem. there is a wire that breaks connecting the two rail releases. find the wire and reconnect it
Why wont my Nissan drivers seat move forward and back?
check for the release wire fully releasing the lock on that side. when you pull on the release lever it is to pull both release locks so the seat will move.
Passenger seat will not slide forward
there will be bars underneath the seat that are supposed to go across to unlock both sides so that the seat can move forward and back, try having someone pull the lever and see if you can see from behind the bar that moves and figure out what it corresponds to on the opposite side. you should be able to move it by hand, release the lock and set the seat where you want it, as for a permanent fix, most seats are not difficult to remove, typically four bolts, although some take specialty tools like large torx bits, and i would imagine the bar is replaceable
4helpful
What steps to take to remove third seat in 2001 chevy surburan
All actions to be done from the trunk area of the 2001 Suburban
1. Lay seat back down by lifting lever 1 and pushing seat back forward.
2. Grab center lever (labeled 2) at seat bottom, back, middle. Pull up on lever and on bar to roll seat up onto it's front.
3. Pull finger tab at center of seat (unlocks seat from floor) and pull seat towards back of vehicle on rollers.
4. Lay seat down. Seat is a beast and best to use two people to get seat to the ground!
How to move forward the Driver's seat of the 2000 Honda Odyssey Driver's seat
the knob on the left side of the lower cushion if its power seats push it forward, if not power pull the lever under the front of the cushoin UP to move the seat
10helpful
2answers
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
98 Breeze Drivers seat forward / back adjusment won't work.
look under the seat and first see if something is jammed under it.... and that the wire that moves with the lever is intact. different instructions if that is a power seat.
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
