Question about Lexmark C533DN InkJet Printer
LIGHT FLASHING TWICE THEN PAUSE THEN TWICE AGAIN CAN'T GET ANYTHING TO PRINT
Light flashing twice then pause again can't get anything to print. i have a lexmark optra s+
Posted on Oct 17, 2009
I have to turn power switch off then back on on my minimax NT , then service light will flash once blower comes on for 20 sec. then shuts off i have nothing. What part should i throw at it first
Any fault codes?
what about the flashing Red light?
how many times is it flashing quickly? It will pause between message/code of quick blinks.
To assist, more info needed.
Jun 02, 2015 | Pentair Minimax NT Heater
My check engine light blinks once, pause, twice,
If it's like some vehicles, each set of flashes of the check engine light represents a "code". So, the code your vehicle is giving you is 12345. You may check with a dealers service department or you may even be able to Google the code and you should be able to figure out what the problem is. Normally with your check engine light, it's more than likely an emission problem such as an oxygen sensor, loose gas cap, etc.
Jul 27, 2010 | 1995 Nissan Pathfinder
Green power light is flashing and red light next to it stays lit
A flashing green on printer light generally means its waiting for a command for instance, push print, stop etc... also check that the pause button has not been pushed. if so depress again to release printing process
Jul 11, 2010 | Epson Stylus Photo 1280 InkJet Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
The red standby light is flashing twice with a pause, then twice and a pause etc. There's no picture or sound and the light flashed whether we have the tv on or off. Any suggestions?
This blinking is a diagnostic code. Please update this with the model number. These sets contain circuitry that will shut the set down and display a code like this when a problem is detected. With the model number, I can look up the problem and provide potential repair suggestions.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
6 orange and 1 green flashing light on S400 canon bubblejet
Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Apr 09, 2009 | Office Equipment & Supplies
My sony kp53hs10,the standby light blinks ,with no picture.
I've got exactly the same problem. Initially, I saw it flashing twice, pause, twice, pause, twice... I pulled the plug when it failed to respond at all. And then when I plugged it back in, it went into the continuous flashing mode. Halp!
Dec 13, 2008 | Sony KP-53HS10 TV
ERROR CODE FOR FLASHING LIGHTS
Hi, Kindly remove your carts then replace then again. try this 2 to 3 times repeatedly. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 20, 2007 | HP Deskjet 460c InkJet Printer
Lexmark C533DN InkJet Printer Logo
106 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
