Question about GE Refrigerators
Freezers cold frig is not MOD-197D3168P003 - GE Refrigerators
  • 65 Answers
SOURCE: Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Posted on Feb 18, 2008
refritech08
  • 149 Answers
SOURCE: Have Maytag side by side
the notorious Adaptive defrost did it again (lol) verify the condition of the heater putting a voltmeter on the "beeping" feature if it beeps its good.
Replace the Adaptive Defrost board and defrost thermostat and should work like a charm
Posted on Apr 26, 2008
freetek
  • 5568 Answers
SOURCE: freezer cold refrigerator not cold
It almost sounds as if your fridge is stuck in a defrost cycle.
The timer for this is often located behind the grill at the bottom and sometimes is constructed with a visible shaft that you can mark to see if it is running at all. Some units are constructed so that the defrost heater and compressor can't be on together, others are made so thoughtful. If you don't see a shaft, you might try an old mechanic's trick of using a screwdriver with the tip pressed against the timer housing and the handle pressed firmly behind your ear for bone conduction. If you hear anything like motor noise during the time the compressor is not on, then the timer is probably OK. If you hear nothing, then it might have failed.
Posted on Oct 20, 2008
The Duff Man
  • 3 Answers
SOURCE: Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Posted on Jan 22, 2009
whytfang
  • 170 Answers
SOURCE: Jenn-air side-by-side: freezer & frig cold on the bottom not top!
It sounds like 1 of 4 things...
1. It could be related to the evaporator becoming Iced over and when this happens it insulates the area iced over and the temp rises...this is caused from the defrost cycle not being activated...(Thermostat, or loose or broken wire)
2. There is a device called the thermistor which senses temp and Ice build up which will cause the unit to go into defrost...this could be bad.
3. The previous fixes may cost a little but not as much as the next which could be a restriction in the evaporator. This is serious and usually requires the replacement of the same...very pricey. Is there only 2 compartment or a pull out drawer for freezer foods..If so you could have an isolated problem in the upper freezer compartment which may be remedied without great cost
If your husband or yourself ..or a handy person can access the back of the freezer by removing the back panel I'm sure you will find either lots of Ice good..as far as cost to repair goes....or no Ice...bad...bad.. as far as cost to repair..the later falls in line with a restriction.
I hope I have helped....please rate me ...The Fang
Posted on Mar 27, 2009
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Freezer cold but fridge is not Whirlpool Mod. ET18LKXHWO
Check for excess frost on the evaporator coils and check the ducts between the cavities. The cooling is done in the freezer and the air is circulated to cool the frig.
Eric
Nov 22, 2009 | Refrigerators
GSS220 side by side refrig does not defrost and no longer cold
the frig is cold by the air for the freezer so if it all ice insinde no air can pass to the frig 1 turn off you frig ,, yes it not fun but you will reset the frig ( more that 3 hour )
meanwile , take out the ice of you freezer ,lower you temperature in the freezer and restart
if it do that a other time , it easy it you temperature detecter it is broken .. some you need to change it
Jun 07, 2009 | GE Refrigerators
Frig is not getting cold at all and the freezer is not freezing Thanks
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
May 27, 2009 | Freezers
Frig not getting cold
See if the coils are blocked with ice. Fridge gets cold air from freezer, ice would prevent this thus a warm fridge.
May 10, 2009 | Refrigerators
Freezer freezes, refrigerator is 55 degrees
All refrigerators also have a return air vent. You need to make sure this is not blocked by frost, the units own foam insulation or even by product placement. You should find it behind the crispers in the bulkhead between the freshfood and freezer compartments. You also want to verify the supply duct behind the damper is not blocked.
May 03, 2009 | Refrigerators
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Feb 18, 2008 | Refrigerators
Refrigerators Logo
189 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
