Question about Toshiba 53H71 53 in. Rear Projection Television
53h71 toshiba projection TV with noise in picture
Ive had a technician come out and replace 2 convergence regulators to try and solve my problem with wavy lines and noise in my picture and it didnt do a thing. when I turn the tv off it takes 45 min to an hr to see a somewhat clear picture and the picture is still wavy at the top and shuttering. can yo help
  • 87 Answers
Re: 53h71 toshiba projection TV with noise in picture
The problem you have is on the hyper module located behind the rear input panel. Inside the shield there are about 6 or 7 10mf/16v surface mounted capacitors. Replace them and your problem will be history. As for the shop that did the repair they owe you a call back to do it right. However, request that you get a different tech to come out. Do not attempt the repair yourself, it involves excellent soldering skills and parts removal. Good luck
Posted on Nov 27, 2007
0 characters
3 Points
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
I was told by repair shop that the hyper module on my Toshiba 53H71 has gone bad, and they were not available for unit to be repaired . Any help ?
there are a few shops that can physically repair these. I have personally repair a few. but is very very tricky... it requires some very trick soldering to some very small was replaceing so many of these they gave instruction on fixing these. it involves replacing 11 very small micro capacitors.... like i said very labor intensive. my shop generally charge 250 for the repair. just depend on who you get. WARNING this is the kind of repair that the technician can easly do more damage than good so get a respectable experince tech to facilate this repair
Nov 03, 2010 | Toshiba 53H71 53 in. Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
I have a Toshiba projection tv 53HX71 and I get 2 or 3 red shadows on everything, how do I fix it
The convergence IC's need to be replaced (possiply 2 fuses will also have blown) this is a common problem.
Sep 18, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71
Either the convergence or cracked sautering. Just had my tv repaired but now I have a double blur in the upper left corner.
Jul 20, 2009 | Toshiba 53H71 53 in. Rear Projection...
Hitachi 65F710 convergence problem
you have to unsolder the old one and put in the new one it should be located just forward of the tuner
Nov 20, 2008 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53h71
Convergence amp ic bad
Or send to
Feb 21, 2008 | Toshiba 53H71 53 in. Rear Projection...
53H71 Toshiba
Look carefully at metal jumpers feeding b+ to convergence IC's.
Both will need re-soldering or you will keep having problems.
Let me know how it goes.T.
Oct 04, 2007 | Toshiba 53H71 53 in. Rear Projection...
Samsung SP42W4HPX
The convergence wouldn't cause it to go all green. Green outlines yes but, not all green. Get a technician to look at it.
Mar 06, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
87 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
