Question about Acer Aspire 5500 5570-2609 Laptop
Laptop ACER Aspire 4920 Screen goes dim.
1- I recently unplugged my laptop from AC connection and then the screen went dim.
2- Since then I can never get it back bright again once connected. I do only have it bright by pressing fonction and brigthess buttons.
3- Whenever I unplugged it from the AC power it goes dim.
Could you please give me solution to solve this problem and how to avoid it happen in future.
Thank you very much for your help.
Joshua
There is a configuration of each one of the three plans of energy, and there you can change the time the screen is on when plugged or unplugged, the brightnes, and some stuff more like the wireless. you have to go to "energy option", or something like that... mine is in spanish. and then under each option is the configuration. good luck!!
F.R.C.
Posted on Sep 02, 2009
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hello..this a normal for laptop if your Battery Pack is not a running Good..
Tips: if you want to Long Life the Battery Pack remove the battery if you their on House then use only a AC Power Adapter Supply but 1st make a full charge the battery be for you remove this Battery pack.the Battery Pack is only for out door..good luck and have a nice day...^_^
Posted on Jul 14, 2009
My acer aspire 5532 just went black. The power button goes on' but no response whatsoever. Any clues?
Just try this steps
1) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
2) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
3) Load BIOS setup Default
4) Try to go to safe mode
5) Do system restore when your computer was working fine
I hope this will answer and fix your issue
Regards
MAJID KHAN
Nov 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
I have recently replaced screen, inverter and cables on my acer aspire 4920 laptop as i had screen problems. The screen is very dark but still working under torch light. all the new parts are in working...
Please try to replace your cold cathode fluorescent lamp or CCFL... I hope this will solve your problem,, It is located on both edge of your LCD screen... Good Day and I hope this would help...
Aug 16, 2011 | Computers & Internet
I am having aspire 4920 model. it is not turning on. at start up keyboard lights are on but there no screen
sounds like your screen has lost connection through the wire.
1. unplug your battery
2. unscrew the screws on the back of the laptop
3. make sure your cables are connected(dont touch unless it does look like it is not in)
Hope this helps
Mar 22, 2011 | Acer Computers & Internet
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 24, 2009 | Acer Aspire 5735 Notebook
Laptop screen flashes... i.e.... goes bright then dim
Check your power supply. Maybe its wire is broken then intermitently making contact every now and then. Its my first suspect. Its like disconnecting and reattaching its power supply only in much faster way. Or test it with a good similar power supply if this will be the same.
Hope this one helps already.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Connecting an external monitor to acer 5720
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
-David-
Jan 09, 2009 | Acer Aspire 5720 Notebook
Problem with Acer Aspire 4920 notebook
all laptops are supplied with a pre installed copy of windows and the product key will be on a genuine windows sticker on the back, unless you have no sticker, in which case you will need to purchase a copy, as nobody is likely to be able to help if you have no product key and no Vista disc
Aug 15, 2008 | Computers & Internet
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
1,124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
