Question about Sony STR-DE597 Receiver
One speaker is lower volume than others - right front
Hello, I have had my system for nearly 2 years and all of a sudden my right front speaker is playing at a lower volume than the other speakers - I have ensure the wires are correctly and securely placed, I have also swapped speakers and its not the speaker its a system problem. Any suggestions (a setting I have wrong?). the test tone shows its only this speaker.
  • 1 more comment
  • toels Feb 22, 2008
    Hi, i just recently bought my system, but when i play tv, the right speaker is lower than the left front speaker. i have checked the connection is okay.
    and when i play a dvd, it plays fine. so i am not sure what's the problem
  • Anonymous May 24, 2008
    I have had my system for 3 years and all of a sudden my right front speaker is playing at a realy low volume than the other 3 speakers - I have ensure the wires are correctly and securely placed, I have also swapped speakers and its not the speaker its a system problem. Any suggestions ? ned to rplc transistors ?!
  • Stephe96 Apr 30, 2009
    Same thing here. The volume of the right front speaker is noticeably fainter when I run the 'test tone' feature. I've isolated the problem to that output on the receiver; it's not the wires or the speaker.
I think that maybe you setted the distance of the speakers wrong. Check your users manual and try to adjust the distance.
Posted on Apr 29, 2008
What is wrong with my system? All plugs are in properly and volume is turned up. Blue light on front in lite.
If you're talking about speakers plugged into a Windows computer, then look in the lower right-hand corner near the time, and you should see a speaker icon. Right click that icon, and select "Open Volume Mixer" from the menu that pops up. On the mixer, make sure none of the volume levels are set to Mute.
If the levels look normal, try right-clicking on that speaker icon and selecting "Playback devices" from the menu that pops up. Do you see your speakers there? Is the green check mark on them? If not, click on the speaker, then click the "Set Default" button.
May 18, 2016 | Audio Players & Recorders
One speaker has suddenly become lower in volume than the other. I switchd wires and the problem switched too.
Switch speakers to see if the problem is the speakers or the amp.
If it is the amp. make sure that the balance control is set to the mid point.
Does the same problem exist whether it is radio, CD or other source? If so, you need to see a tech if you are not
qualified to do some deeper digging inside the circuitry.
If it is the speaker, see if you can open it up by removing the
front grill to expose any screws around the edge of the box.
Possibly a wire has come loose, or the filter in the speaker
has a problem. A bad speaker can also happen if you really
push the system a lot.
Do you loose all volume, or just the high notes or just the low
May 30, 2011 | Panasonic Home Theater System System
I can't locate the volume control button
what is the operating system you are using ?
Mar 01, 2011 | Computers & Internet
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
1. Sub should be on about your knee level or below,
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 06, 2010 | Logitech X-530 Computer Speakers
Hello i have a toshiba l305 laptop and can't get the internal mic to work with any program that uses it
The Microphone might not be working, as it may not be enabled.
However, you may enable the Microphone manually by performing the below steps:
For Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. 4) Click the OK button. 5) Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
For Windows Vista:
1) Right click Speaker near Clock - Recording Devices - right click in box - check 2) Show Disconnected Devices and Show Disabled Devices - check your mic - highlight them and then on lower right properties. 3) Make sure the proper one is enabled and check other settings - on Levels tab make sure MUTE is unchecked and APPLY / OK changes.
For Windows 7:
1) Right click on the volume icon in the system tray and then click “Recording devices”. 2) Right click on the blank place in the popped up window and then select “Show Disabled Devices” and “Show Disconnected Devices”. 3) Right click on Microphone and then click “Enable”. 4) Highlight the microphone and then choose “Set as Default Device”. 5) Click Apply. 6) Select Microphone and click on Properties. 7) Click on Levels tab. The default Microphone Boost is set to 0, increase it.
Hope this helps.
Jun 23, 2010 | Computers & Internet
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
One speaker has much lower volume than the other
No i beleave you blew out a channel ...move the good speaker to the other jack that way you can tell if it the amp or the speaker (speakers dont smoke or smell when blown ..AMPS do!
please rate my responce to you
thank you!
Dec 13, 2008 | Soliloquy 5.0s Main / Stereo Speaker
Sony STR-DE597 6.1 Channels
Repair time ...circuit board to front channel has a fuse prob or capacitor
May 24, 2008 | Sony STR-DE597 Receiver
Speaker volume on one side extremely low
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
Jan 24, 2008 | Dell A425 Computer Speakers
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
Sony STR-DE597 Receiver Logo
653 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
