Question about Dell 924 All-in-One InkJet Printer
Blinking error light
Inserted new cartridge but light continues to blink tho printer appears to work. Cannot find any other fault to causr this.
    Scholar:
  • 40 Answers
Hi : fraserellers ,
if the printer works fine with the led still flashin ., then the problem is with the printer h\w (sometimes the sensor could worn out )....
or ., try this ., when the printer is on , simply unplug and replug the power adaptor or cable on the back of the printer .
reply for further help and support
hav a gooday !
Posted on Jul 26, 2009
Epson artisan 1430 printer wont recenize new cartridge
If you removed and re-inserted the cartridge then ensure that the contact points are clean . If you are using refilled cartridges then the printer would show an error
Jun 25, 2015 | Epson Office Equipment & Supplies
Why do I continue to get the E error message and blinking light on cartridges
The 'Ink Alert' or 'Low on Ink' message displays on the computer or on the product control panel.If the cartridge has been refilled or re manufactured, 'Low on Ink' or 'Ink Alert' or error messages appears on display panel.Replace with the new genuine cartridge which is showing error on display..
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
Ink indicator keeps on blinking even with new ink cartridge.
The blinking ink light means that the printer does not recognize one of the ink cartridges. Power the printer off, pull out the power cord, wait for awhile, replug and turn the printer on. If the light no longer blinks, ok. If not, try installing another cartridge pair if you have them available - even if they are old used ones. If the ink light continues to blink with different cartridges or if you don't have any different cartridges, old or new, you have a dilemma. Do you want a new printer or do you want to continue to chase this problem. To chase this problem, get new cartridges and install them (half the price of a new printer). If that works your set, but if not you need to have your printer serviced which is doubtful that it is worthwhile doing so.
Mar 03, 2011 | HP DeskJet 810c InkJet Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Canon iP100 ink tank read error, put in new one and won't read
I am having the same issue with the black cartridge error light is on. Three new cartridges create the same issue.
Nov 30, 2009 | Canon iP100 Portable Printer
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Printer mechnical error
    Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
    • Change the printers print mode setting.
    • Change the printer's paper type selection.
    • Use a different brand of label media.
    There is a paper jam Follow each of these steps until the problem is resolved:
    1. Remove the paper from both paper trays.
    2. Press the Power button once. Wait a moment for the paper jam to clear.
    3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
    4. Remove the rear access door.
    5. Remove the paper jam through the opening at the back of the printer.
    6. Replace the rear access door.
    7. Reload the paper into the paper In tray.
    8. Print the document.
    There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
    1. Remove and then reinsert the print cartridge(s) into the printer.
    2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
    3. Manually clean the print cartridges and print cartridge cradles:
      • Open the printer cover and wait until the carriage moves to the center.
      • Press the Power button to turn off the printer.
      • Disconnect power cord from the back of the printer.
      • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
      • Lightly moisten a cotton swab with distilled water.
      • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
      • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
      • Reinsert the print cartridges.
      • Close the printer cover.
      • Connect the power cord to the back of the printer.
      • Press the Power button to turn on the printer.
    4. Calibrate the print cartridges.
    5. If the light is still flashing, replace the print cartridges.
    Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
    1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
    2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
    3. Remove and then reinsert the print cartridge(s) into the printer.
    4. Print the document.
    5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
    6. Try printing again. If the problem continues, replace the print cartridges.
    Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
    Inserted new cartridges..orange light still on
    Try re-seating the ink cartridges. A lot of times, the electrical contacts on HP's ink cartridges do not make a solid connection.
    Jun 17, 2009 | HP DeskJet 880c InkJet Printer
    Orange cartridge light error keeps on blinking!
    clean the carriage home
    check the data cable for the carriage home
    check the media sensor on the left of the plotter media bar
    Mar 12, 2008 | HP DesignJet 450c InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
