Dell inspiron 8100 no ac power-power only with battery
My buddy had a dell tat his power supply was bad. i used mine to power his and it charged his battery. when i pluged my power supply back into my dell inspiron 8100 (his is same) nothing happens. then i plugged it back into his and it now will not work off ac. bought new adapter. it works on his but not on mine. my will work off battery but will not charge. bought another adapter and new battery. battery works but no ac power or charging. what could be the problem?? thanks
    President:
  • 1,564 Answers
You may have to run the battery/charger utility test.Look under control panel classic view.
Posted on Jul 24, 2009
Plugged in not charging on Dell Inspiron 1525
your answer to your problem lies here.
http://www.howtomendit.com/answers.php?id=141277
If you have the battery at a low level and it's not charging then i think i might have worked out what might be the problem:
First flash the BIOS to Revision A17 (or later if available)
Then power off and turn on the laptop with AC adaptor plugged in, hit F2 to go into BIOS and go to Battery Info.
If you can see 'AC Adapter 65w' at the bottom then there shouldn't be anything wrong with your power supply or the laptop. If it says 'Unknown' then there's a problem with your motherboard or the AC adapter.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
Bought a Dell Inspiron E1505 Laptop
I have a e1705 dell and mine I had to replace the power cord .The battery was not charging.
Jun 26, 2009 | Computers & Internet
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 9400 will not charge - AC adaptor not recognised
Does the laptop power up just no charge the battery? If the laptop does not power on then you may have a bad power supply in the unit. If it does power up than you most likely have a bad battery connector of blown fuse on the motherboard. The flashing of the BIOS is done with a bootable cd or floppy but this will not keep the new battery from charging. The reason Dell states that you need at least 10% battery to flash a BIOS is because if your AC power goes out while you are doing a BIOS upgrade and you don't have battery power the BIOS will be incomplete and your laptop will not boot again without replacing the motherboard.
Jun 17, 2009 | Dell Inspiron E1705 Notebook
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Battery Not Charging
Sounds like the power supply has gone bad. You should get a new power supply. You will get this message when he power supply goes bad
Feb 12, 2009 | Dell Inspiron 640m PC Notebook
New Dell battery, new AC adapter(not Dell). Won't charge battery
Dell uses a proprietary SMBus protocol over the center pin to communicate the type and power capability of the attached adapter. The laptop uses this information to determine if it can charge the battery without browning out the motherboard. If you use a knock-off power supply that doesn't communicate properly (or at all) over SMBus, then the computer will complain and won't charge the battery. Sorry, Dell has us all right where they want us. Find a used actual Dell adapter on eBay for $20 if you can.
Nov 15, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 8100 won't boot
Send it in to a repair facility, usually runs 80-130 online through ebay. Inspirons are known for blowing fuses/resistors. This may have happened, but either way if you pull the new battery and it dont work still with charger or vice versa you have a power issue on the motherboard.
Good Luck!
Ruben
Nov 08, 2008 | Dell Inspiron 8100 Notebook
Battery will not charge
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
