Hi, it's better to take your TV to a service center or call a TV service technician because electronic boards inside could be faulty and they need to be repaired or replaced.
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
The sometimes it works OK puzzles me a little, but I will do my best here. From the description you gave my first thought is the water saver in the aerator. If you havn't already, remove the aerator on the end of the spout and turn on the water and see if that makes a difference. If so you may want to remove the water saver from the aerator. It is usualy a plastic peice about the size of a dime with a small hole or holes in it. While you have this apart you may want to clean the screens as well. The works sometimes may mean that the diverter dor the spray is hanging and that is another story alltogether. Try the aerator fist. I hope this helps.
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
There is a slight film on these and once damaged is a real pain to clean, what we do here is spray the rag with rubbing alchahol then clean the screen, several passes may clean it up, but never spray the screen, this allows fluid to leak down past the front and this can kill the set real fast
There should be 2 to 4 screws, depending on the model, to take out on the bottom of the screen assembly, then you lift the entire screen up and pull it out towards you. Good Luck
the fluid has found its way down to the buttons. Slide the circuit board out and clean the switches with an electronic contact cleaner and toothbrush, it will evaporate quickly but make sure it is dried and give it a try.
I dont think your daughter did any damage bacause the water can not get into the set form the front unless the water went in thru the holes in the back,in that case water can cause a lot problems,it will dry but it will also damage some components,if the water went in from the back you need to take it somewhere to get it clean so it does not built up corrosion with time.Good luck.
