Zenith dtt901 converter box has turned itself off
Our converter box has turned itself off, and no amount of pushing the power button on the box helps. All cables are plugged in correctly. From researching on the internet, we think we may have pushed the sleep button on the remote by mistake while the tv was off. Now we can't figure out how to power up the converter box. How do you turn the box back on after sleep mode has turned it off?????
  • 1694 Answers
SOURCE: When I am trying to turn on the tv by remote or pushing the power buttton it goes to stand by mode
Solder bad connections vertical output IC......requires chassis
to be pulled....................T.
Posted on Dec 06, 2007
Joed911
  • 4338 Answers
SOURCE: Computer won't turn on unless I unplug the Ethernet Cable
Is the Ethernet built-in on the system board? I would go to BIOS (hit F2 while booting the PC) and disable the ethernet. then restart the PC. See if it stays on with or without the Ethernet cable plugged in. If it does. The built-in Ethernet circuit is the problem. I would buy a Ethernet adapter ($20).and install it. and leave the built-in ethernet disabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
  • 5 Answers
SOURCE: vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Posted on Oct 20, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
  • 56 Answers
SOURCE: blue screen when the tv is on
The TV or converter box might have lost the cofiguration for the converter box
Posted on Feb 03, 2009
Zenith tv converter box stopped working
I just replaced two DSTV converters that abruptly failed so your guess probably is right on target.
Sep 12, 2016 | Zenith Dtt901 Digital Tv Tuner Converter...
How do I program a Toshiba remote to a zenith converter box
Signal converter boxes are pretty easy to set up - ABC News
abcnews.go.com/Technology/AheadoftheCurve/story?id=5485537
Digital Switch: How to Set Up Your Converter Box. ... If you subscribe to cable, satellite or some other pay-TV service, you'll continue to receive programming. ... aToshiba TV in my kitchen: Magnavox's TB100MW9 and Zenith's DTT901. The boxes are simple enough to set up, though I prefer the Zenith's remote control and ...
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!
Zenith remote control code list - channel recovery morning ...
www.thompsontv.com/zcodes.html
Dec 15, 2015 | Zenith Televison & Video
Have a Zenith DTT901 converter box, need the remote codes for my zenith remote, thanks
Your Zenith remote should be able to control your Zenith DTV box. If not, your remote may not have the latest codes or it could be defective. You may have to try a newer programmable remote.
Dec 10, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Where can I download a schematic for a Zenith dtt901 converter
Try the manufacturer's website and/or do a Google search using
" Zenith dtt901 manual pdf
Nov 08, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Lost remote - moved to new state - need to have new rescan of local channels
You probably will have to get a replacement Zenith remote but there are some remotes available that can control your converter.
Aug 13, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Have a Zenith DTT901 converter box. In cold weather when you go to power on the unit, it shuts down and you need to remove and play with the plug several times. This does not happen in warm weather. The...
A known problem with this model. Due to poor design or construction, it doesn't operate reliably below normal room temperature. You'll need to move it to a warmer spot.
Dec 26, 2013 | Zenith Dtt901 Digital Tv Tuner Converter...
Color lost on TV after hooking up Zenith DTT901 converter box
Try unplugging it if color regains its the box and not the TV!! if it dont regain then the flyback needs to be looked at. I am sure its the box and not the TV and yes had problems with zenth boxes Thank you
Apr 23, 2009 | RCA F32665 32" TV
Zenith dtv converter, favorite channel button
Found the solution in the user manual. You have to go to the 'edit channel' section of the on screen menu.
Dec 30, 2008 | Zenith C27A24T 27" TV
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
