Engine or hydraulic system overheating
Coolant system low on coolant in 6020, 6030, 6030 Premium, 7020, 7030 and
7030 Premium Series Tractors.
Symptoms
After several hours of work, warning system indicates hot engine coolant or hot hydraulic oil.
Situation or Problem
Coolant level in reservoir is between the "MIN" and "MAX" range but engine or hydraulic system is overheating.
Summary
Air is entering cooling system, hindering coolant flow. Check coolant level. Fill to the "MAX" line on the coolant reservoir.
Bleeding Cooling System:
The bleed valve (see
Operator's Manual for location) on the radiator must be closed when the tractor is operating. Open the valve when coolant is drained or filled. If the bleed valve is left open, coolant will internally bypass between the low temperature circuit and engine high temperature circuit causing overheating. When bleeding the system, open the bleed valve and run the engine with no load for 5 minutes at 1700 rpm. Then shut engine off for 5 to 10 minutes before closing the drain valve. Check the coolant level. If level is below the "MAX" fill line, repeat this procedure until coolant level stays at the "MAX" line.
