Question about Yamaha 12V Air Pump
2005 Yamaha FX won't go over 4 mph
I have a 2005 FX, it has been in the water a couple of weeks - kept on a jet ski dry dock. It was running well all weekend then when I pushed it into the water it idled fine and pushed water through the back but when I tried to accelrate the RPM's would increase but there was no power and it vibrated substantially. I could barely get enough power to get it back on the dry dock. Any thoughts?
  • perrotta Jul 14, 2009
    do i need to take it out of the water to check this? any specifics would be appreciated about what I am looking for, oh one other thing if I rev it out of the water it did not shake like it did in the water. I imaginge that has to do with the impelar pushing water and its ability to do so.
    thanks
    Top Expert:
  • Yamaha Master
  • 76,164 Answers
If I understand you then this problem may be the jet impeller, check to see if it is loose or the coupler is damaged, is anything clogging the water intake to the jet.
Posted on Jul 14, 2009
  • 3,741 Answers
You will need to take it out of water to check out the wires as in water it will not get checked also if thay are proper the water will make them spark.get it checked by a professional technician.as its not a majopr job but .will habve to check properly. thanks.please do rate the solution.
Posted on Jul 15, 2009
What now ?? my yamaha suv1200 Can the transmission be shot ?
there are no gears just a direct drive from the crank to a jet pump ! if theres no propultion of water it could be several things !
1. plastic bag etc in the intake to impellor pump assy !
2. impellor gap to housing too much ie worn impellor !
3. impellor not turning because splines on either the shaft or impellor worn !
4. drive coupler damaged and spinning on shaft !
Try running on a hose pipe and look at rear of engine ( remove plastic cover so you can see the 2part coupler and drive shaft ) .
Check the impellor assy !
Sep 08, 2014 | WSM 1999-2001 Yamaha Suv 1200 Cc Jet Ski...
Why does yamaha waverunner fx cruiser ho not run in lake but will run hooked to water hose
Sounds like you have a bad stator. It may be producing enough spark to start the motor, but under a load (as in the water) it simply can not supply the amount of spark needed. Sometimes when a stator is tested on a ohms meter it may test good, but still be defective do to the load it will come in contact with when put in the water.
Jun 29, 2014 | Yamaha 12V Air Pump
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
2010 Yamaha FX Crusier jet ski
sparks ? compressions 100psi or more ? water in fuel ? injecters clean ?
Jul 14, 2013 | Boating
My Yamaha Jet Ski 750, turned over Bro.. my Jet Ski, Yamaha 750, turned over and after that.. I pulled out of the water took the spark plugs out, put DW40 in the cylinders and nothing happened.. the e
sounds like you hydro locked it and possibly blew out a reed in your engine intake or worse, you may have bent a crank rod. But before you go tearing it apart make sure all the water is out of motor and theres none in the fuel tank then put in a new set of plugs and see what happens,
Mar 18, 2013 | Water Sport
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
My 2005 Yamaha FX HO Waverunner runs smoothly, but will only go 38 to 40 mph. The RPM Limiter is off, intake is clear, oil level is good and air cleaner is ok. Should I replace the spark plugs?
yes yes yes the new yamahas foul plugs like crazy i dont know if it is a valve defect or what but you will be changing them every year one trick i have been doing to my coustmers watercraft and has been working well insead of ngk cr9eb plugs use a cr8eb it is a hotter plug there for it will burn better and no it will not hurt your ski trust me i have over 15 yrs ex and 6 in r&d research and design
Jun 26, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
153 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
