Question about Philips Magnavox 51MP392H Rear Projection Television
Picture problems when i turn on the tv the picture bends at the sides and has now left a 1" gap on the left side of the tv.
  • Anonymous Nov 22, 2007
    My picture has a blue hill across the bottom of screen. Picture is green with pink double vision wording. Whats up with it?
  • Ironhorse87 Nov 24, 2007
    Yes! I have the same problem with the blue hill on bottom of screen. I found that if you turn it off and on repeatedly, the problem goes away and sometimes comes back, but eventually it is OK after awhile. However, if you turn it off for awhile the problem comes back. Best thing to do is turn it on, wait about ten minutes, then turn it off, then back on. You may have to do this several times until the problem goes away. I have had this set for a little over 3 years and this just started about 8 days ago. I bought a 4 year warranty, so i am covered. This TV has gotten alot of bad reviews. I like the design, but just can't deal with the problems.
    Genius:
  • 1,694 Answers
Convergence IC's need replacement,moderate technical ability
needed......cost about 400.00 to repair..................T.
Posted on Nov 22, 2007
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Kpr-46cx10 picture issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Televison & Video
KP-57HW40 rear projection TV colors out of alignment and warped
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Jan 04, 2010 | Sony KP-57HW40 57" Rear Projection...
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
Striped color distortions on Nokia 300 Xa flat panel
This is power supply problem.
1. First u replaced the power out put capacitors , 6V, 12V, etc.
2. cheak the diodes.
Oct 17, 2008 | Computers & Internet
Rca p61960 projection tv
That sounds like a Pincushion problem if you having bowing. It's probably bad caps and diodes on the deflection module. This is not an easy fix. If you know how to read a diode and you visually inspected the caps you might have some chance of fixing it yourself.
Aug 17, 2008 | RCA P61960 61" Rear Projection Television
LG Plasma picture probles
hi there. I have this same TV, and the exact same problem. Last night, i was playing around with it, took off the entire back of it to see if I could fix it. After a few minutes of tinkering, I found that if I apply pressure to the TV in a specific way, the left side of the picture comes back. Here's what I did: standing in front of the TV, I hold the top of it, in the middle with my right hand, and the upper left corner with my left hand. Then, I gently apply pressure, forward (away from me) with my right hand, and backwards (toward me) with my left hand. Sort of like trying to "bend" the screen. At some point, the picture comes back .. . the problem is, if I let go, then the colored lines come back . . . maybe one can mount it on a wall in such a way that the pressure is still there . .. i haven't tried. That's all I got.
Oct 27, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Weird arch like lines
Hello HollyJ, If possible can you post a picture of the problem, It would help in determining if this is a convergence problem or a pincushion circuit problem. You description while good is a little to general to many possible issues. This sounds like a defection issue but I would not be able to tell unitl I see a picture of the screen, take the picture with a digital camera and the post it to the page using the add image link on the right side of the dialog box. Thank you, Shuttle83,
May 12, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
