Question about Samsung HL-S5087W DLP TV
I have a Samsung HLS5087W that has recently started shutting off for no apparent reason. When this happens, the first and third indicator lights will blink for a few seconds and then the standby light comes on and I can turn the tv back on. The amount of time I can have the tv on before it shuts off varies from a couple of hours to a few minutes with no pattern. I have double checked the lamp cover to make sure it is secure and there does not appear to be any problem with it.
  • soulstess Jul 14, 2009
    I wasn't sure if you meant the source button or the activate button when you said to press the input button so I tried both. However, I did not get the sequence of blinking you described with either combination BUT I have had the TV on for a couple hours now and it has not shut off. So, perhaps it did work. I would like to wait a day and see what happens before closing the question. Thanks
  • 10,594 Answers
When first and third LED blinks in Samsung TV, repair manual says to check following..
1. Check that the fan operates when LED for timer,
standby or abnormal temperature blinks.
2. Check that the cover detection switch is inserted at
CN310 on the digital board when LED for timer,
3. When LED for timer, standby or abnormal temperature
blinks, check that the lamp cover is properly assembled
and that the switch-pressing boss(inside) is not bent.
Hope that will help to solve your TV problem.
Thanks.
Posted on Jul 14, 2009
  • 3,230 Answers
PRESS and HOLD the MENU AND INPUT BUTTONS on the FRONT of the TV set for 8 seconds....it'll start to blink...
It will blink TWO numbers.....so count the first set of blinks <pause> second set of blinks <Long pause> then it starts over and does it 3 times in a row....
Good Luck!!
Thanks
Why does my tablet shut down while i'm using it.
Check its battery. If battery is weak, this type of fault can happen. Replace it with a new one, and check. Electro help
Jun 22, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
Lamp comes on but without picture
The color wheel is the likely problem here.
Nov 27, 2012 | Samsung HL-S5087W 50" HDTV
Samsung 50 inch DLP has power will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.Note lamp sometimes doesnt look bad when it's bad.The lamp you need is BP9601472A you can find it here http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm?Click=48173.Have a blessed one!
Apr 29, 2010 | Samsung Televison & Video
Tv plays for about 10 min then 3 lights on front start blinking turns tv off
Hi,Is your tv between 6000-8000 hrs or 2-4 yrs, and are getting the 3 led lights.If so it might be time to replace the lamp.Your part # will be BP9601472A and you can find it here: http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm and here's the instructions to replace it: http://www.fixyourdlp.com/guides/samsung/BP96-01472A.php Have a blessed one!
Mar 22, 2010 | Samsung HL-S6186W 61" HDTV
HLS5087W DLP Samsung Fan problem
Replace it if fan to Lamp stops running this will fix problem Call Mats 1-800-628-1118
Sep 16, 2009 | Samsung HL-S5087W DLP TV
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
My t.v. shuts off after a few minutes
try this link...it tells you what the LEDs indicate. Apparently the cover on the back is not sealed properly, my guess is that it is a fan not working properly or some other reason the set is overheating.
http://downloadcenter.samsung.com/content/EM/200604/20060404091311750/EN/3_sub.htm
Oct 31, 2008 | Samsung HL-S4266W 42" HDTV
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Samsung HL-S5087W DLP TV Logo
174 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
