Question about Brother DCP-8065DN Black and White Copier
I have a Brother DCP-8065dn that need to have anew fuser installed. I have changed fusers in a few HP machines in the past with no problems. Are the fusers in the Brother machines as easy to replace as the HP machines?
  • tommy445 Jul 14, 2009
    Thanks for the instructions as well
  • Brother Master
  • 19,396 Answers
It is not too difficult, more or less the same as on HP.
Allow the machine to cool down completely, then open scanner cover and open the back cover to access the fuser unit.
The fuser unit is held by two tabs, or on older models by two big screws.
Remove two screws , two at each side of the fuser and pull the fuser out.
Do operations in reverse order to fit the new fuse.
See also here , instructions are for a similar model: Brother: FAQs & Troubleshooting.
Posted on Jul 14, 2009
How do you change the fuser unit on a brother printer
Should the unit require a new fuser, you will need to unscrew the back panel to remove the core.
A roller can be replaced without replacing the whole core.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 10, 2012 | Brother DCP-9045CDN Laser Printer
What they mean by change Fuser?
There are a few more parts that are needed for a Laser printer to work than a inkjet. the fuser is a component that literally superheats the ink and "fuses" it with the paper once the powder in has been laid down. It needs to be replaced when it cant properly fuse anymore;
I reccomend you contact their tech support to properly resolve this issue
navigate here
https://www.brother-usa.com/Support/Default.aspx
down at the bottom where it says "contact customer service", select "Multi-function center (MFC and DCP series)" and give them a call.
Thanks,
Mike
May 16, 2010 | Brother DCP-8060 All-In-One Laser Printer
Part number brother 9840cdw fuser
Part# LU4103001
About $150
The service manual will be hard if not impossible to find. They only release those to factory authorized service centers. If you just need it for the fuser replacement instructions then often those will be either in the operators manual which is easy to find or the instructions will be in the box that the fuser comes in.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Worgh toner was put
There may a jam in fuser area in rear of machine. Check there by opening rear door and sliding the black paper chute left and downward to look inside fuser area. Look for paper or a worn fuser such as black marks or lines on top or bottom rollers. Make sure machine is off and unplugged. The fuser gets very hot. Let cool down before attempting to view area of fuser. Do not pry out paper or objects from fuser. This may damage fuser more. Use your fingers only if possible. If there is no paper or black lines, your problem may be else where. Let me know and I may be able to help some more. Thanks!
Feb 14, 2009 | Brother DCP-8065DN Black and White Copier
Brother 7020 printer "fuser error"
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Mar 19, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother 7020 Fuser does not warm up
dcp-7020 fail to warm - how do i reset if i turned off and on already and waited 10 minutes
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-8065DN Black and White Copier Logo
330 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
