Question about Juki DDL-8300
There are no instructions on how to attach the pedal to the motor... I know where it attaches, but the lever on the bottom of the motor will not move. How do I do this??? Please Help!!!
    Scholar:
  • Juki Expert
  • 176 Answers
PLEASE TELLME MACHINEMODEL I WILL TRY TO HELP
MY EMAIL IS aabozid@hotmail.com
best regards
Posted on Oct 31, 2009
Pneumatic air foot petal
If the machine won't work with two pedals that are good then the problem isn't the foot pedal. Does the light turn on? If this is functional then you know there is "electricity" attached to it. Since both pedals aren't functional you will have to have the motor and connecting cord (inside machine) to see which is the problem. By the way; if the problem is the cord inside the machine you may not want to plug it in. You stand a chance of getting shocked. Have it checked for safety.
Sep 27, 2016 | Sewing Machines
Where can i order a foot pedal
Carolyn, Google search your make and model# foot pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sewing Machine Foot Pedal eBay
Sewing Foot Controls SewingMachinesPlus com
http://www.sewingmachinewarehouse.com.au/machine-accessories-feet-needlesglobesspare-parts/foot-pedals-and-power-cord
http://www.a1sewingmachine.com/parts.html
Jul 23, 2016 | Sewing Machines
Hooking up the two wires from the foot controller to the 3 prong plug on thebsewing machine
Ok. One of the wires provides power to the machine. It will attach to the motor directly from the power cord. The other two wires go to the pedal. Really, it's a circuit. One wire runs power down, when the pedal is up, no power to the machine. The other wire runs electricity to the machine when the pedal is pushed down. I am sorry I can't be of more help. Knowing the color of the wires would be helpful.
Mar 20, 2016 | Sewing Machines
Why won't the foot attach?The lever at the back seems to not be working and it won't come down to attach the foot
it may need to be checked to see if there is something wrong with it, may need to be replaced
Mar 05, 2016 | Sewing Machines
Elna 2130 runs slow and won't go to full speed?
1. Make sure the bobbin assembly is clear of all left over rags, threads, etc.
2. When you return the hook (sharp thing) it needs one drop of oil on the track. (track is what the hook rides on)
3. Take off the top and bottom lids. (Not too difficult)
4. While turning the hand wheel you will see parts moving. At areas that you see metal against metal movement. Place sewing machine oil on these areas. You may want to start by cleaning with a qtip first.
5. Make sure the needle arm (going up and down that is attached to the needle) gets oil. Also, put a small amount of oil on the pressure foot arm. (has a spring around it)
6. If it isn't still working as fast as you would like do the following.
7 Remove the plate that surrounds the hand wheel.
8. The rubber part that goes between the motor and the hand wheel may need to be replaced. (Not usually the problem) Just give a glance and see if it is in bad shape. If so then replace.
9. The motor and the hand wheel need to be aligned. Loosen the bolt that attaches the motor.
10. (Remove needle) Give the foot pedal some pressure and move the motor to a point where you hear the motor move the fastest and with very little resistance. This is where you will tighten the motor.
11. Put your machine back together.
Jul 10, 2015 | Elna Sewing Machines
I have a singer 6202 sewing machine and I need to know how to attach the walking foot for quilting. thanks
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
May 22, 2010 | Singer 7436 - INGENUITY
White euroflair 8910 motor won't turn on
motor inside the casing you have to remove the cover motor at the rear beside the handwheel of sewing machine loosen set screw or lift upside machine bed so you can see the motor and wiring circuit,if bottom cover is present loosen bolt remove cover you can check motor wiring using multitester setting to R10 set switch on and setting test probe red and black rod attaching the two terminal of male plug start pedal switch besure it was unplug on ac source if there resistance on the circuit and the motor.If negative result.Isolate checking the electrical circuit.check continuity of switch,if ok.check armature winding of the motor in two terminal of the motor, you have to pull out motor inside the casing first remove belt from the motor and handwheel.Loosen the 3 bolt from motor holder to the casing.In motor assymble unlock and pull out two carbon brush attaching tha armature brush replaced a new one pair of carbob brush and install back again.besure winding was not
burn out otherwise you to replaced the motor.
Mar 07, 2009 | Sewing Machines
Singer 7436 beeps - not working
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
May 26, 2008 | Singer 7436 - INGENUITY
Juki DDL-8300 Logo
47 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
