Question about MSI Computers & Internet
When I try to switch on the power on light just flashes and the laptop doen't switch on
  • janle10 Jul 14, 2009
    Ive tried that and its still flashing
  • MSI Master
  • 4,806 Answers
The reason for the laptop not booting could be a number of things, first of all remove the battery and try to boot it on AC power only, then get back to me with the results.
Awaiting your reply
Posted on Jul 14, 2009
Hp probook 4530 ac connected indicator flashing. will not power up
Either your charger is not providing the perfect voltage or there is a short circuit in your motherboard. Try replacing the charger first. If still the problem persists then you should check the connector. try resoldering it cause loose connection in it also sometimes causes this problem.or you need to change the motherboard finally.
Feb 08, 2012 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Hi. my flash drive light comes on as i put it in. it stays on momentarily but after three seconds or so th ligh goes off. it doen't even show up on my computer
Flashing light means your flashdrive is being read. Try it on another computer, if it still can not be detected then it is broken.
Hope this helped! =)
May 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Printer will not print, power is on
Make sure you do not have a driver issue. Also make sure that the printer says its "online" and is set to the default printer.
Apr 26, 2010 | Office Equipment & Supplies
My HP dv1000 does not start. I checked both adapter and battery ( new ones), but still the problem persists. And the adapter makes a beep sound 2/sec, doens anybody know what it means. Please help me out.
i don't think it's your adapter which beeps, beep indicates Ram problem, does your laptop power on? if it does power on and you don't see anything on the screen then it is because of RAM. Try switching ram to other slot, or get a new ram.
Feb 01, 2010 | HP Pavilion dv9000z Notebook
Will not power up
If you hear the fans working at boot up and then the laptop shuts off after 10 15 seconds or more, you may be having a overheating problem, which you can fix by dusting off the fans, and if you want to do a deep clean, open the laptop and clean the heatsink and apply a heat release compund. (This is a liitle extra work).
Also you can try removing the RAM and change slots.
But if the laptop doen;t stay on for more than 5 seconds, you may have a motherboard that went bad...(sory no fix for this one, just replacement)
Please don't forget to rate this answer if it helps
Oct 30, 2009 | Dell Latitude D600 Notebook
The laptop won't turn on
Hi..
This seems issue with the power supply.
If the computer is in warrenty call dell.
Thanks
Smith
Aug 15, 2009 | Dell Latitude D530 Notebook
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Computers & Internet Logo
32 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
