Question about Toshiba SD-P1900 Portable DVD Player
My toshiba portable dvd player (sd-p1900) won't play discs. We have two, and the other one works, so it's not the disc. When you put a disc in, it doesn't spin, and it says that there is no disc.
I had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Posted on Jul 20, 2009
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Howdy...I have a Toshiba SD-P1900
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Jun 23, 2011
Dvd not spin player
You need a spacer; without it reading is impossible
Aug 25, 2014 | Toshiba SD-P1900 Portable DVD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Feb 06, 2010 | Toshiba SD-P1900 Portable DVD Player
Disc read error
Dear Sir,
After 2-3 years generally all optical drive lenses goes bad,so first try by cleaning lences,if it not solves your problem then try by replacing lence of your DVD Drive,if you have any problem regarding this issue leave a feedback we will glad to assist you.
have a nice day
good luck
Sep 11, 2009 | Toshiba SD-P1900 Portable DVD Player
No Valid Disc - Toshiba SD-P1900
Yep sone of a gun ! With the Toshiba Portable DVD Player, hold the "Mode button" down for several seconds and it will make a chain saw noise take your finger off, hit it again once and bingo now it works. I was ready to throw this player in the trash!
Jan 17, 2008 | Toshiba SD-P1900 Portable DVD Player
Toshiba SD-P1900 Portable DVD Player Logo
886 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
