SOURCE: car won.t start makes a clicking sound
this is always the starter solenoid that does this, replace the starter solenoid.
SOURCE: Van won't start. Just makes a clikcing noise. Horn sounds weak.
THIS IS CAUSED BY A DEFECTIVE STARTER MOTOR SOLENOID, REMOVE AND REPLACE THE STARTER OR JUST REPLACE THE SOLENOID ON TOP OF THE STARTER IF YOU CAN BUY IT SEPERATE.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
SOURCE: 2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
