Question about Garden
I cranked my White riding mower up and drove about 100 foot and it started smoking real bad. I took air filter off and it was full of oil.
  • 155 Answers
Sounds like the crankcase breather is stuffed i would be checking that first.
Posted on Aug 04, 2009
When I start my ride able Ranch King Mower I get white smoke. I just had the oil changed & they did a Compression test - 100 psi and it is good. They did a leak down test 100 in -90 hold and it is
I only use 10w30 in my shop, and also have you checked to see if they over filled the crankcase with oil. The dipstick must pe pushed or screwed all the way in to check the oil..
Nov 24, 2014 | Garden
I have a Briggs stratton 14 hp ohv I/c quiet model 287707. I had a guy change the oil & he put 10W30 synthetic oil in it. Now it smokes white smoke really bad. I think he put the wrong oil in
There is a very real difference between 30W and 10W30 oil. Whether it's synthetic or not probably doesn't matter. If you have the literature that came with the mower, it will tell you the recommended engine oil.
If they put in the wrong oil, they should make it right. You shouldn't have to pay twice for an oil change. It could be burning oil, since 10W30 is a lower viscosity than 30W. I would have them change it again, and see if it stops smoking.
TRACTOR WILL NOT STAY RUNNING
Give it a tune-up, spark plug, oil change, fuel filter, air filters... Drain gas completely from gas tank and carburetor... Fill with fresh fuel. White smoke from muffler means there is water in the system... Fuel "goes bad" as soon as 1 month.
Nov 18, 2013 | Garden
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
I have a Simplicity model 1692762 with a 16hp Briggs and Stratton. The mower blew large plume of white smoke three times while cutting grass over a period of 10 minutes. Engine seemed to lose some power...
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
May 27, 2010 | Garden
Oil leaking from air filter area of push mower and mower smoking
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
Jun 24, 2009 | Poulan Garden
Engin fogs the neiborhood with air filter on.
Sounds like it's pulling oil by the rings/valves -- the air filter is creating more suction. I would try a small amount of an oil additive for high mileage engines. Follow the mixing/proportion directions on the bottle. Sounds like this engine is "wearing out".
May 07, 2009 | Mtd Garden
TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Mar 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
