Question about Samsung ML2251N Laser Printer
Samsung ML2251N printer will print multiple pages of code upon print request. A simple 'test page' request sees 6-8 pages of code, and no test page.
    Problem Solver:
  • 13 Answers
If it is connected with parallel cable than replace data cable. Otherwise reinstall your printer
Posted on Dec 03, 2013
SOURCE: Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Posted on Jan 04, 2008
  • 40 Answers
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Posted on Jan 12, 2009
  • 684 Answers
SOURCE: lexmark x4650 AIO, will only print first page of multiple pg doc
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Posted on Feb 05, 2009
Healeyman
  • 1198 Answers
SOURCE: Can't scan multiple pages into 1 document
Be kind m'53. Maybe you can scan to a folder, then use print setup to compile all the data on one page, if it's not much data. You'll have to do all this with the computer, don't expect the scanner to do that. There is always lots of software out there to do this kind of stuff.
Posted on Apr 26, 2009
SOURCE: Samsung scx-4521f-How to scan multiple pages to single pdf file?
get acrobat professional, its pricy, but it workes
Posted on Nov 11, 2010
How to get a test page on the samsung
Hold down the Cancel button for about 2 seconds to print a demo page
Refer to manual for more help
http://downloadcenter.samsung.com/content/MM/200212/um_ml2250_manual_eng_040819.pdf
Hope this helps
May 20, 2010 | Samsung ML2251N Laser Printer
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
Print is light and can be rubbed off easily w/my ML2251N laser printer. Just changed out toner w/new OEM cartridge. Printer has 5,000+ prints.
I think you have a fuser related issuse, low heat, not enough presure but Samsung says this ...follow link
Try their solutions and then try creating service request and see what they say.
Oct 13, 2009 | Samsung ML2251N Laser Printer
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
Lexmark x4650 AIO, will only print first page of multiple pg doc
Feb 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer Anamoly?
when turning ON your printer and you hear that is going to print HIT the cancel button right away and then go to the menu see if you see a setting named DEFAULT hit that , turn off printer ,wait a couple of seconds a turn on again , it should stop printing automatically, hope it helps
Mar 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
Samsung ML2251N Laser Printer Logo
93 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
