Question about Dell Inspiron E1705 Notebook
Computer is not recognizing the dvd/cd drive
Fairly new acer desktop computer is not recognizing that there is a dvd/cd drive - I cannot find this drive when I go to "computer" - usually all the drives are listed there. What should I do? Do I need a technician or can I fix this myself?
    Sergeant:
    Champion:
  • 315 Answers
Call acer support. might need some warranty work.
Posted on Jul 14, 2009
My cd /dvd rom (dvd/cd burner) is hide..my pc doesnt recognize it..help please..i dont know if i lost a driver
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 26, 2013 | Acer Aspire X1200 PC Desktop
Cd burner drive won't recognize dvd
You could spend $40 to buy a new CD/DVD reader/writer, or you could spend $50 to $75 for a computer-technician to _try_ to trouble-shoot. Your call?
Sep 17, 2010 | Acer (91.37H37.001) Internal DVD Drive
Optical drives do not recognize disk when trying to load new disk
If you cannot read those CD-disks in _any_ computer, then the disks are "bad".
If you can read those CD-disks, then it's time to replace the CD/DVD drive. Find a smaller computer-store -- often they will remove the "dead" drive, and install the "new" drive, for $0.00, or for a small fee, if you buy the new CD/DVD-writer from them.
Nov 18, 2009 | Dell Inspiron 530 -Intel® Pentium®...
Sometimes the DVD drive will not open. It is fairly annoying.
Sir,
Go to My Computer and right clicked on the DVD Rom drive and clicked eject. If any error appears let me know. Also try to insert a straightened paper clip into the designated hole on the CD/DVD drive casing to manually force an eject. If it is not worked replace the cables(master slave).
Thanks Good Luck
Aug 06, 2009 | Acer Aspire E500 PC Desktop
My Laptop no longer recognizes that it has a DVD/CD drive
If you can, remove unit from laptop and start laptop without CD/DVD. It is usually fairly simple to remove. Maybe a few screws in bottom of laptop. Cut off laptop and reinstall. Restart and windows should find it.
Jun 28, 2009 | Acer Aspire 9300-5349 Notebook
New ACER ASX3200/8450 Desktop PC DVD/CD not woking
Hi.
Either the drive is faulty (yes, they fail right from new more often than you would think), or the master slave jumper may not be set correctly on the back of the drive. If the PC came fully assembled, I would take it back and get the tech to check it. If you setup the hardware side of it yourself, check that the jumper is correct for the master/ slave situtation of the drive and make sure the cables are pressed in firmly.
Mark
Mar 01, 2009 | Acer Computers & Internet
DVD doesn't open
This problem may be a bad cd/dvd drive. When the computer boots up, go into the BIOS setup. Check to see if the computer recognizes the drive, and make sure it is not disabled. Next, check in the "device manager" to see if there are any yellow question marks or red X's. This might indicate a driver problem, or a misconfigured drive. If these steps fail to resolve your problem, replacing the drive would be your next step. This is a fairly easy task, and worth the time to research the steps for your particular model.
Nov 15, 2008 | Gateway MT3705 Notebook
CD/DVD not working, lapto doesn't recognizes it
It sounds like a problem with part of the I/O for the CD drive on the mother board. If the computer is under warranty, I would see about sending it back for service.
Normaly, if you are using original supported devices, if the drive is not defective and the drivers are installed, it should work.
Jerry G.
Jul 19, 2008 | Acer Aspire 5610-4648 Notebook
Lost DVD Driver in Windows XP Pro!
DVD Driers. DVD's do not have drivers. A DVD Drive could need a firmware update. What kind of drive is it. What kind of computer. Have you checked the jumpers or cable? Try changing the cable. What software are you using to burn your DVD / CD's? What OS is this? There are several things that can cause this. Is your computer recognizing it? Right click my computer and go to properties and check your hardware area for ? marks.
Mar 10, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
ASPIRE T135
Is it a new dvd drive? how old is? what brand and model is it? Is your dvd drive showing up in "my computer"? Is your computer recognizing it?
Dec 17, 2007 | Acer Aspire T135 PC Desktop
Dell Inspiron E1705 Notebook Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
