Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Fuse burned and tv power went off . we replaced it and still no power at all.
    Genius:
  • 1,153 Answers
Read threads here or at ctechnicians.com
Posted on Dec 22, 2007
Power to T.V. went out
Try first unplugging tv for one hour .
Sep 04, 2008 | Samsung HC-P4752W 47" Rear Projection...
The power went off today and my coby 40 inch tv would not power up
when the power goes off there is often a power surge as the power comes back on, this can burn components in the tv. sometimes if you are lucky it is only a fuse but they are inside and should be replaced by a technician. always have your major appliances connected to a surge protector or if the power goes off unplug everything until power is on steady to prevent surge damage.
Jan 23, 2015 | Coby Televison & Video
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
MY MAGNAVOX TV MODEL#30MF301B FUSE BLOWING UP AS SOON AS I PLUG IN
The power suply board has a severe short and will most likely need replacement. You can get replacement power boards fom www.tvcircuitboards.com
Feb 06, 2013 | Magnavox 32MF301B LCD TV
In the middle of tv being on, it suddenly went off and cant be turned on. Power is on to all other componenets
The trouble of your tv is the power supply. Try to open the back cover of your tv and try to check the fuse if busted. But be sure to unplug your tv first before engaging in trouble shooting. In order to find the main power supply, try to follow the ac cord it will direct you to the power supply then try to look for the fuse, if you see the fuse try to observe if the fuse wire is only broken try to replace it with the same rating, if the fuse is totally burned out do not just replace it, it has a shorted parts commonly the regulator and the bridge type rectifier.
Jun 10, 2011 | Philips 34PW8502 34" TV
TV JUST WENT POP NO SOUND AND NO PICTURE
good day hope I can be of help to you...is your TV "dead set" if so try these easy steps to trace the problem.. check the power cord for any burn or cut wires...check for a blown fuse... if you replace the fuse w/ same type and if it still been blown do not try to replace it again.. if this happen you have a defective power supply...let a certified technician now do the troubleshooting...good day...
Feb 13, 2011 | Toshiba 42LX196 42 in. LCD HDTV
Will not work at all
check for the power supply is locater at the back of the tv..you need to open the cover.the output power of the the power supply is 5vdc for the cpu and 12v-24dc for the backlights..visually inspect the components of the power supply.replace any burned capacitors and resistors..replace the secondary fuse with the same ratings..
May 17, 2010 | Niko SV3206 32 in. LCD Television
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
Replace the FU303 fuse
I have just been buying it at radio shack. However in my case it seems once the fuse blew for the 1st time, it happens now every few months -- so must be a symptom of a larger issue.
Dec 18, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
