Question about Nokia 6233 Cellular Phone
Problem with connecting port
Headset and data cable diconnected with slight tough only i think the port is damaged
Tip
How do I Wire a USB Cable to a Stereo Phone Plug
<p>In general, the audio devices use audio cables such as RCA stereo headphones, or telephone cables, connection to other devices. In case you need a USB device to a stereo phone plug, you should use a single adapter cable to connect the USB cable will convert to a stereo phone. <br /> <p><br /> <p>1. Connect the USB end of the headphone adapter to the USB port of your audio device. <br /> <p><br /> <p>2. Connect one end of the headset to your male cable to the headphone port of the headset USB adapter. <br /> <p><br /> <p>3. Connect the other end of your headphone male to male cable to the headphone port of your stereo plug. Now you can connect to any port to connect to stereo. <br />
on Aug 05, 2011 | Cell Phones
Telephone headset to pc
do you want to sell it ? What's the problem. i think something like bad or no sound or at one side-->. buy a new one
Jun 20, 2014 | Sennheiser UUSB-2 USB Cable Adapter, Easy...
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
For some reason the computer cannot find or recognise my camera and keeps saying communication error ?
Ok. there're three possible causes for this. I'll list them and the relevant procedures of resolution by probability of occurrence.
  1. Damaged data cable- (confirmed if the following 2 doesn't fix the problem) if this is the case, you need to get a new cable.
  2. Damaged USB port on computer- Confirm by trying to connect cam to a different port (i.e.- try the rear ports if you were using one on the front) or to a different computer. If this is the case, you need to get a USB expansion card that will give your computer some extra USB ports.
  3. Damage on camera's side (could range from a simple broken port tab to circuit damage) confirm by: connecting a different camera to your computer using the same data cable. If this is the case you will have to take the camera to where you bought it from for repair (remember to check whether you can still claim your warranty.)
Sep 25, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I connected my S11 plantronics headset to my Cisco 7900 at work and can hear, but callers can't hear me
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Jun 03, 2011 | Plantronics S11 Headset
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
My n70 is not recognized when I plug in my USB cable. I am trying to download photos from my nokia N70 using a USB cable and its like its not plugged in to my laptop, nothing comes up when usually it...
there is a possibility that the cable is damaged or the phone port is damaged slightly in the data port. I was going to tell you to download drivers but it seems that it was working before so its either 3 things, computer, cable or phone. 92% of the time its the cable, just try another one. Please let me know if this works for you.
Oct 17, 2009 | HP Compaq Presario v3000z Notebook
Light only lights up while charging
are you pressing and holding the button for 3 seconds until it flashes 3 times as that is howyou turn it on and off, not by simply pressing the button and then letting go.
Jun 24, 2007 | Motorola Mobility H500 Wireless Headset
Nokia 6233 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
