Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
My week old GE top freezer refrigerator makes a fairly loud rasping sound coming from the freezer. The technician says it's the kind of freon GE is using. I didn't pay a thousand dollars to listen to an asthmatic refrigerator. Anything I can do before I tell them to come and get this hunk of junk? Model # GTS18ISXBRSS. Thank you.
    Champion:
  • 363 Answers
Replace the unit now
Posted on Jul 22, 2009
  • geoffkeg Nov 27, 2010
    I absolutely agree with jhhoppe. I have a GE refrigerator model #GTS19QBNCRBB that made noise from the beginning. They sent a technician out right after we complained about it. He replaced something and it stopped making as much noise. Now 9 years later, it is back to making a bunch of noise again. If we had simply replaced this thing outright I do not believe it would be making any noise at all. GE is making defective units, then not exchanging them. I guess whenever you want to make it right you call a class action attorney and sue them as it appears they could care less about your satisfaction as long as they have your $1k. DO NOT accept parts replacement - FORCE them to replace the entire refrigerator for a quiet one.
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
GE Top-Mount Refrigerator GTH22SHS, freon escape?
Even though technicians may wear a patch which says GE , is does not mean they are electronic refrigerator capable . Most probably know very little refrigerator repair .
From your description , it sounds like the 2 freezer thermistors could be bad . 1 is located on the freezer side panel inside a small oval housing . This thermistor tells the main control board , the actual freezer temp and when to cycle on / off . The second thermistor is located on the top of the coils , behind the inside rear freezer wall . This thermistor is " clipped " to the coils . Both are 1 " long , torpedo looking pieces , which you can easily replace ( only 2 wires to each ) . The thermistor on the coils , tell the main board the coil temperature and when to defrost .
The part number for both is WR55X10025 and cost about $10.00 each .
May 15, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerator and freezer cools at bottom, but not at top.
first thing to check for is your fan running if yes than does your freezer freeze enouht to freeze water if not you need more gas or should i say freon possible freon leak thanks from gilles
Jan 20, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The Top Freezer Is making a Loud buzzing Noies!
Hello psimmons304,
Yes it does sound like a issue for the fan. What i would do is look up the model on google and type in replacement fan. you should be able to find it that way.  If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | GE Profile Arctica Stainless Steel Top...
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
145 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
