Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
New Bosch dishwasher mold before cycle
I have only used this brand new Bosch dishwasher 3 times and the last two times i have found mold growing on everything before a cycle. I made sure to rinse items BEFORE putting them in and they've have only been in the dishwasher for 3 days.
I have never had this problem with any other dishwasher.
Two friends have similar Bosch models and they have never had this problem.
any help appreciated.
    Sergeant:
  • 228 Answers
Leaving dishes in the machine this long is bad for you and your dishwasher they should be washed within 24 hours of stacking modern dishwashers use a lot less water ,heat and detergent than the older ones so will not tolerate this kind of stacking and being left you will end up giving yourself a stomach upset.
Posted on Jul 21, 2009
  • Craig Sep 23, 2013
    Who could possibly fill a new dishwasher up to capacity in 24 hours...the Duggars? Other brands don't have these issues and perform better. The Integra Ascentas are poor performers.
  • 98 Answers
The Bosch is a very good dishwasher and it is very airtight. I would suggest you NOT leave the dishes inside that long, and always use the Power Scrub Plus cycle if you have it. It will get the water as hot as possible so mold does not continue to grow in the plumbing and filters.
It is NOT the dishwasher unit causing the problem.
Posted on Jul 19, 2009
    It IS the dishwasher causing the problem. I also have mold growing on dishes constantly. I had mold the very first time we used it. I get mold after rinsing the dishes off and there are sitting for more then a day. Maybe we just need to run it constantly...that will fix the problem. This is a known issue to go along with the god awful smell these have.
Does not dry the dishes
The drying problem is most likely related to the heating element or the thermostat. Both are inexpensive parts, compared to the cost of a new dishwasher. But to test them requires removing them and the use of a multimeter. The instructions for your particular machine should be available on the manufacturers website. As for the mold, mix a solution of one part bleach for ten parts water and spray down all surfaces. Wait ten minutes and run the dishwasher through the rinse cycle.
Mar 08, 2012 | Dishwashers
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Major calcium build up. what will cut through it?
Hello there and happy new year as well
How to Clean a Dishwasher Dishwasher manufactures tell us that the inside of dishwashers should not need cleaning---after all, it is constantly being cleaned as you wash your dishes. You know better. There is a slimy feeling on the walls or door gasket of your dishwasher---or there is something black "growing" at the bottom of the dishwasher by the drain---or it doesn't smell very nice---or there is a white coating on the heating element (even manufacturers acknowledge this one as common). What do you do? The first thing is to try to prevent as much of this as possible: 1) Be sure your water is coming into the dishwasher at a minimum of 120°; 140° is even better. If your water heater is a long ways from your dishwasher, before you turn on the dishwasher you may need to run the water into the sink until the required temperature is reached. If the water is not hot enough, the detergent (even gel detergents) won't completely dissolve, and you get the slimy feeling on the walls and gasket of your dishwasher. You also foster the growth of bacteria and mold or mildew in your dishwasher. 2) Be sure you are using the right kind of dishwashing detergent. Manufacturers usually recommend using certain brands. That is because they have tested those brands in their machines, so they know they will work. Others may do fine, but they haven't been tested. 3) Be sure you are using the right amount of dishwashing detergent. Ironically using either too much or too little can cause similar problems. The amount you need depends on the hardness of your water, not the amount of food left on your dishes. Okay, you've got all that under control. Now, how do you clean the dishwasher? Problem 1: Slimy feeling on walls and gasket ---Use good old soap and water (yes, soap to clean soap residue!) and clean away. Be sure to rinse well. If you don't you may have suds coming out from around the door the next time you use the dishwasher! Problem 2: Something black "growing" by the grates at the bottom of the dishwasher ---You have a mold problem. This is also what causes a bad odor to "grow" in the dishwasher. The mold is caused by food particles not getting fully pushed through the drain hose when the dishwasher drains. The drain hose is corrugated, and bits of food particles can sometimes collect on the ridges and in the valleys of the corrugation. Given the right circumstances, this can cause a gradual buildup inside the hose, just like cholesterol in our arteries. The presence of moisture and lack of sunlight in the hose allows mold to grow on these food particles. You will want to remove the grates at the bottom or back of your dishwasher (usually removing just a couple of screws will do it) and clean with bleach water (a cup of bleach in a gallon of water) as far down as you can reach. After you have done that, replace the grate, put the rest of the bleach water in the bottom of the dishwasher and run a regular cycle (no dishes, please!). Why not just put the bleach water in and run the cycle? Because that will kill the mold, but will not remove its build-up. You want to remove the build-up first, as far as you can reach---it's easier to remove when it's live. Then kill what's left in the drain. If your problem was serious enough, you may want to replace your drain hose, too. Problem 3: Brown spots on the door gasket ---This is mildew. Mildew can also cause a stale odor in the dishwasher. Use the bleach water recipe to clean the gasket, and then run the rest of the bleach water through a cycle, just as for Problem 2. Problem 4: White coating on the heating element ---This is a build up of minerals, mostly from your water. You may have heard people recommend putting TANG® Drink Mix in the dishwasher and running it through a cycle. This does work to help remove the calcium from the heating element. That is because there is citric acid in TANG®. However, the sugar in it may contribute to other problems you have been trying to clear up. So why not just use plain citric acid---what an idea! You can often buy the crystals in a drug store or in the canning section of the grocery store---it is used for making jelly with a fruit that does not have enough acid in it to allow it to jell. Fill the dispenser cup with the crystals (3--4 ounces), and run a cycle. If the build-up is unusually thick, you may need to do this a second time. So, now you have a clean dishwasher! How do you keep it that way? After all, who wants to have to go through all of those steps every so often? The best thing to do is occasionally run it empty with a cup of white vinegar and a cup of baking soda. How often depends on your water quality, how often you use your dishwasher, how much food you leave on your plates, etc.o there and happy new year as well
Jan 01, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Jul 29, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Black Mold growing inside dishwasher
this is an easy fix use 1 part bleach to 10 parts water and wipe down this will kill the mold you may need to do this several times
Dec 08, 2008 | Dishwashers
Kenmore Quietguard 3 has mold and is dirty inside
G'day, I have a Miele Dishwasher and I have only had one small problem with it in the 12 years I have own it. That was due to moving house, a bit of fluff had moved and was blocking an outlet. once cleaned with a brush it now works like new again. Best dishwasher on the market, made to last 20 years.
Nov 25, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
MOLD building on inside of dishwasher
are your dishes comming out dry at the end of the dry cycle and during dry cycle do you see steam comming out of the vent
Dec 31, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
674 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
