Question about NorStar M7324 Telephone
Line in Use
Two of our line seem *locked up* - no one in the building is using these lines, however when we try to pick them up to release them the phone is saying "line in use"... HELP!
It's possible that the last caller, never gave the system the "Disconnect" it needs from the phone company. Try rebooting the phone system. Just pull power on it, let it sit for 10 seconds, then reapply power.
Posted on Jul 14, 2009
I bought this strimmer in May 2015. Works well but the auto line feed doesn't seem to function.
most auto line feeds work off the button in the middle of the trimmer head
you tap the head on the ground while it is spinning and it releases just enough line to continue working
if it is not now doing that then it is more than probable that you have to install new line
Jun 08, 2015 | Cars & Trucks
My 99 eclipse will randomly slam forward like i locked up the brakes but its not the brakes what else could it be?
Brakes just don't do this. This is what people will say - ABS system playing up: to me this just does not seem likely the ABS system is designed to stop lock-ups. Then others will say it is your master cylinder - My experience is more that when these fail they make it hard for you to break. Air in the line usually is a soft pedal and once again no brakes. Stick with me here - For the brakes to work they need fluid pressure - how can fluid pressure build up to the point where it pushes the brakes on? I am thinking some very basic physics here - kinked lines these are not allowing the pressure to be fully released from the line system. I would check for kinked lines and I am also thinking that when you turn this may exasperate the line kinking.
Jan 17, 2013 | 1999 Mitsubishi Eclipse
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
1999 Chevy Cavalier Can not remove the quick connect fitting from the fuel filter. Looks like someone tryed and broke the black plastic part around the fitting where you squeeze to release the line from...
You can use a pick to remove the plastic clip,And use a fuel line disconnect tool to release to line.If you do not have that tool you can get one at advance auto parts.Be patient it may take some time to remove it.
Jan 30, 2010 | 1999 Chevrolet Cavalier
Line one red light constant - voicemail locked up
Sounds like your picking up the handset then pressing the voice mail key, thereby transferring the line to voice mail when you hang up. try pressing the voice mail key before you pick up the hand set.
Mar 25, 2009 | Lucent PARTNER18 Corded Phone
How do i remove fuel line to bemove the head
You need a special tool to disconnect the fuel lines,you can pick them up as a set at auto Zone for not too much.They're just a plastic tool that slips into the line connection & releases the spring lock.Good luck,
ChevRev
Mar 25, 2009 | 1999 Chevrolet Cavalier
Phones will not release hold when picking up on a different phone
Make sure you have filters on the lines between your DSL and your phones. Use the line out from the back of your modem to split to your phones if you don't have any filters. You may have to take line 2 from the back of the DSL modem to send to all of the phones. This is usually a filtered source and should isolate your phones from the DSL. Put the filter on any other devices that are sharing line 2 too, fax, computer, credit card machine etc.
Jan 19, 2009 | AT&T 944 Four Line Intercom Phone
Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Sep 12, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
Aug 19, 2008 | NorStar M7310 Corded Phone
NorStar M7324 Telephone Logo
168 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
