Question about Frigidaire Freezers
We have your Model # FFU20IC8CW1 and we purchased it 12/22/2003. The freezer part works fine. Temperature fine. But the temperature alarm indicates it is dropping when it is not. The temperature works fine, it's just the alarm that seems to be malfunctioning, sounding all day and all night, and we can't seem to get it turned off. Please help!
  • 833 Answers
SOURCE: Kenmore 14.8 cft - temperature between 5 and -22 degrees (-15 and -30 C)
Big...this is likely normal. I'm not sure where you're measuring that temp from. If it is the fan outlet, this is possible. The fact that the unit is staying below 5 degrees means that it is within spec. You do have a warranty. Ask Sears to come on in and check it out.
Your 'duty cycle'...that amount of time that the compressor is on should be about 20% of a unit of time...say 25 minutes out of 2 hours. Is that about right? If so, enjoy your ice cream.
Posted on Dec 04, 2007
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
SOURCE: Frigidaire FFU20F9G (model FFU20F9GW3) temperature light is on
Several things could cause this. To check most things you will need to remove the back wall of the freezer to see the evaporator. It is possible the freezer is low on gas. If it is the coils will usually appear to be only half frosted or less. It is possible the defrost is bad ( I assume this is a frost free) In this case the coils will be totally clogged with ice and no air can circulate. If so you'll most likely have to replace the bi-metal... a circular looking part about the diameter of a quarter clipped onto the coil with 2 wires leading from it. This may also cause the fan to stop running from ice accumulation...or the fan itself could be bad which would also cause a partial meltdown. Unless the machine needs gas an appliance repair person will probably charge you around 100 bucks for most of these repairs..gassing it of course will be more and there is no guarantee how long the gas will stay in it as most leaks are difficult, if not impossible to locate. Hope that helps !
Posted on Jan 12, 2009
  • 82 Answers
SOURCE: Temperature has dropped from a normal 18 degrees
The only thing that will make it cool to low is a thermostat. They wear out and get out of calibration. Check to be sure the temp sensor from the thermostat is tight on the mount. Its the little tube that connects to the evaporator that makes the thermostat work.
Posted on Jul 01, 2009
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
I have the GLFU1467FW0 model Frigidaire freezer, and the temperature alarm won't stop going off. How do I flip it off for good? Pressing the alarm reset button does nothing.
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Frigidaire freezer alarm
What is the model and what temperature have you set the unit for before?
Jul 30, 2012 | Frigidaire Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Temperature Alarm beeping/buzzing Kenmore Freezer 26041
Just incase>>>>
Is your circulating fan working?
It may be slowing down.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 17, 2010 | Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
if the gasket is still sealing allaround the door then u shouldnt be losing any cold. try defrosting the freezer cleaning it out and firing it back up.
Dec 04, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
