Question about Garden
Replacing deck belt
I have a scotts riding mower model 2046h 46 cut and do not know how to replace the deck belt product number is gx2046
  • 123 Answers
Here ya go.
Posted on Aug 26, 2009
  • vondeliusc Jun 07, 2011
    OMG- Thank YOU!
    Sergeant:
    Champion:
  • 226 Answers
Go to parts tree.com.put model # in they should give you a idea of what your looking for.hope this helps
Posted on Jul 15, 2009
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Model rz4623 zero turn deck belt is jumping a lot
see if belt has burn spots in it that will cause it to jump excessively
Sep 16, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Jul 27, 2014 | Cub Cadet Garden
Blade route
I can't give you an answer on this without knowing the model number of your mower.
Sep 25, 2013 | Mtd Oem Deep Deck Belt 46"
I have a scotts riding mower model 2046h 46'' cut and do not know how to change the transmission belt. Thanks for any help.
To whom it may concern, I have a Scott's 2046H lawn tractor # GX2046S042396, I replaced the arm #GY00244 which the original piece was found broken. Now I have the unit back together, but I have no drive, forward or reverse. I checked the belts and pulleys, belt is tight and the pulley's are intact and functioning. Any ideas as to what I should check or do?
Apr 18, 2010 | Garden
I need a belt for th scott 20hp 46" mower model # 2046H. Where can I get it besides a dealer?
You can order them here. If you have the part number it is better (same site) but if no part number
http://www.jackssmallengines.com/find_belts.cfm
(EXAMPLES only... not your actual part number)
The part number for a 5/8 belt is
258077 258 = 5/8 inch belt 077 = 77 inches long. This would be for a 5/8"W X 77L belt.
If you know the length of your belt you can call around town to larger automotive supply stores and ask for the 258___ belt by length.
Mar 30, 2010 | Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
2,165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
