Question about LG Refrigerators
There is ICE in the dispenser, unit is making ice, but ice will not dispense.
    Champion:
  • 363 Answers
Can you hear the wheel turn, trying to dispense.
Posted on Jul 21, 2009
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Ice dispenser wont dispense ice
sounds like a problem with a belt or something or you cango here http://www.theelectricdiscounter.com.au/new/enquiry.asp and ring the nomber
Dec 24, 2011 | Kenmore Refrigerators
Ice dispenser will not work
first check ice making unit is filled with ice, if empty sounds like ice maker water inlet valve not operating.if ice bath full then problem with ice making unit itself,either heater, ice harvest switch or geared paddle motor faulty.either way would recommend changing out the whole unit, alot less fuss and not too expensive
Feb 27, 2010 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Dispenser arm for cube or ice will not move to dispense ice the into door shut. Still makes ice cube.
the ice maker unit is bad and need to be replace its 120$ or less what is your model # ?
911service today . com
this unit cannot be fix you have to replace it :( sorry
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dispser arm for cube or ice will not move to
the ice maker unit go bad fast :( the unit need to be replace unless its under waranty .
sorry but its happen all the time.
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
37 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
