Question about Polaris 380 In Ground Pool Cleaner
Cannot get the back two wheels to turn - Polaris 380 In Ground Pool Cleaner
  • epoolshopcom May 11, 2010
    Which model do you have?
  • 640 Answers
Check to make sure that there is not dirt or debris trapped in the drive system, which is a common problem with these pool cleaners. Also, make sure that you are getting acurate water pressure to turn all of the wheels.
Posted on Oct 11, 2010
Why 4x4 doesn't turn all 4 wheels at same time? 4hi-4lo
4X4 actually provides power to the front 2, and the back 2.
Unless the back has limited slip or posi-track, if 1 wheel spins, the other will not turn.
Since the front wheels have to turn at different rates to accomodate turning radius differences, there is (usually) to limited slip on the front differential, so if one wheel spins, the other will not turn.
So, if you have one front wheel spinning at the same time as one back wheel is spinning, and you don't have posi-trac, you're stuck.
Cheerfuls.
Nov 11, 2015 | 1998 GMC Sierra
2001 Chevrolet suburban 5.3 vortex had to use 4 wheel drive when I put it back in 2 wheel drive and went to make right turn it didn't wanna turn steering is very hard and stiff
sometimes we have to back up a little after going back to 2 wheel drive and I don't know why seems the 4 wheels just stays locked in
Jul 15, 2015 | Chevrolet Cars & Trucks
What cause rear brake to stick?
Possible out of adjustment, bad proportioning valve, bad springs on brake shoes, shoes out of alignment, leaking wheel cylinder. Good luck
Apr 10, 2017 | 1990 Chevrolet C1500
Turn signal switch repair
The steering column wheel has 2 pins pushed into the back side of it and as you turn the steering wheel making a turn, the pins slide over the humps of the blinker signal. As you return the wheel back to center to drive straight, these pins then hit the humps in the turn signal and push the turn signal back to the original position. It sounds like one of these pins fell out or broke off. You need to pull steering wheel and check to see if these pins are still inserted on the back side of the steering wheel.
Sep 29, 2013 | Mitsubishi Montero Sport Cars & Trucks
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
Kia rio steering wheel is locked and won't turn
Okay, I just had this same problem with my 2009 Kia Rio and I did this. So not to down everyone's post on here -- everyone is correct -- by turning the steering wheel back and forth and turning the ignition key at the same time is a correct method. However, after talking to a Kia Serviceman, he told me you have to do it hard -- meaning turning it violently back and forth hard (madman style). In order to do this operation, I had my wife sit in the driver side and turn the key while I was on her left side grabbing the steering wheel and violent moving it back and forth like a madman, and after about 2mins of doing it the key turned over -- problem fixed. Do not worry about breaking anything; turning the steering wheel violently hard is a must -- this was told to me by a Kia service Rep. Remember -- have someone assist you; either turning the key or violently turning the steering wheel back and forth. Hope this works for you!!!!!
Apr 06, 2012 | 2007 Kia Rio5
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 | Cycling
My bicycles chain fell down,and I cant put in on again, Do you know some repairer who can repair it,around the Leytonstone or maybe near it? Many Thanks.
There's a trick to putting a chain back on a bike. First fit it onto the back wheel. Then hold it on the top of the front cog wheel (at the pedals) Get someone to lift the back of the bike so the wheel is off the ground. While the wheel is off the ground and you're holding the chain on the top of the front cog wheel turn the pedals forward, with your other hand, as when you're cycling and as it turns the chain will go on.
If you don't have someone to hold the back wheel up off the ground you could hold the chain on the bottom of the front cog wheel and turn the pedal backwards. The chain will still go on.
Nov 13, 2010 | Cycling
Key won't turn
Well sometimes you can wiggle the steering wheel back and forth even when wheel is locked just apply moderate pressure and try to wiggle steering wheel back and forth and at same time use your other hand and try to jiggle the key to the on position.
Apr 08, 2010 | 2001 Chrysler Town & Country
2004 GMC - can't make turns
I just went to the Meineke. They have told me that it is an all wheel drive vehicle and that both front axles are out and they will need to be replaced $620....
Feb 23, 2009 | 2004 GMC Envoy
Polaris 380 In Ground Pool Cleaner Logo
78 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
