Question about Brother DCP-8065DN Black and White Copier
Brother DCP-8065dn fuser problems
I have a Brother DCP-8065dn that I am being told needs a new upper fuser roller. Is this a component within the fuser assembly?
  • tommy445 Jul 14, 2009
    Thanks for the answer. I have change a few fuser in various HP machines, but have never had to work with a brother machine. Are the fusers in the Brother machines as easy to change as the HP machines?
    Thanks,
    Thanks for the info
  • 3,230 Answers
The answer is yes it is in the fuser assembly.
Good Luck!!
Thanks
Posted on Jul 14, 2009
How do you change the fuser unit on a brother printer
Should the unit require a new fuser, you will need to unscrew the back panel to remove the core.
A roller can be replaced without replacing the whole core.
Aug 10, 2012 | Brother DCP-9045CDN Laser Printer
I have just put in a new toner but still the
change the print mode and try in printing best mode.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Brother DCP-8065DN Laser Printer
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
My brother dcp8065dn laser printer seems to be leaking ink and leaves a line and dots of ink on the paper
The problem is coming from drum unit . Clean the OPC of your drum and doctor blade (it is a brash which is situated upper side of the opc) and clean the corona wire to solve the problem.
Jan 04, 2010 | Brother DCP-8065DN Laser Printer
DCP 8065DN
please print option paper source setup mp tray and setup page size then solve your problem
mp tray is copier front side open it and insert paper or print source lower casset
i pray you wiil success
Sep 03, 2009 | Brother DCP-8065DN Black and White Copier
Worgh toner was put
There may a jam in fuser area in rear of machine. Check there by opening rear door and sliding the black paper chute left and downward to look inside fuser area. Look for paper or a worn fuser such as black marks or lines on top or bottom rollers. Make sure machine is off and unplugged. The fuser gets very hot. Let cool down before attempting to view area of fuser. Do not pry out paper or objects from fuser. This may damage fuser more. Use your fingers only if possible. If there is no paper or black lines, your problem may be else where. Let me know and I may be able to help some more. Thanks!
Feb 14, 2009 | Brother DCP-8065DN Black and White Copier
I have the Brother MFC-7820, I just purchase a laptop with a Windows Vista. I am unable to use the printer. What do I do?
23/Feb/ 07: Updated the Brother original driver(Full Driver & Software Package) for the following products to fix a driver installation problem: FAX-2820, FAX-2920, DCP-7020, DCP-8060, DCP-8065DN, MFC-7220, MFC-7225N, MFC-7420 ,MFC-7820N, MFC-8460N, MFC-8660DN, MFC-8860DN, MFC-8870DW, MFC-9420C
And here is the link of the updated full driver and software package. After you download this, you should be able to run the MFC 7820 with your new laptop=)
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother DCP-8065DN Black and White Copier Logo
656 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
