Question about IBM Office Equipment & Supplies
What was the model number for a selectric typewriter ribbons in 1983? Would the ribbon still be good today?
  • kristenking Jul 15, 2009
    Would the IBM model number 1299508 be from this same year?
    Would the model number for the Tech III ribbons be 1136390? I see orange ribbons model 1229905 by IBM and would like to know which was more common and widely used in 1983?
  • 336 Answers
IBM 1983 selectric typewriter uses the IBM 210 Correctable Ribbon. So the IBM model number 1299508 ribbon is the one you are looking for.
Cheers!
Posted on Jul 15, 2009
  • 580 Answers
The 1983 IBM Seletric Model saw a new design Tech III refillable Cartridge design, It provided greater security as it was harder t remove from the typed page. Tech III Boxes were coded pink for standard quality, and were coded blue for higher quality. It may be good today. If the Cartridge packaging is still sealed and air tight, and was not exposed to the elements. 1983 IBM Personal Selectric Pictured
  • 5,081 Answers
IBM #1299095 this is the model number for the ribbon . i believe it will be good try using it but i cant assure
Posted on Jul 14, 2009
What would cause the ribbon guide to not lift to ball strike position?
Check ribbon adjustment there is an adjustment lever that adjusts the ribbon up and down.Also check that the ribbon is still good not wore out,out of ink.
Jun 27, 2014 | IBM Correcting Selectric III Electric...
How can I determine whether my typewriter is a Selectric II or III?
The video shows the models C, Selectric I, and Selectric II.
If your typewriter doesn't compare to any of these in the video it is most likely a Selectric III.
This will also help:
The Selectric III featured a 96-character element vs. the previous 88-character element. IBM's series of "Electronic Typewriters" used this same 96-character element. The 96-character elements can be identified by yellow printing on the top plastic surface and the legend "96," which always appears along with the font name and pitch. The 96- and 88-character elements are mechanically incompatible with each other (they won't fit on each other's machines) and 96-character elements were not available in as many fonts as the older 88-character types.
Jul 09, 2013 | Office Equipment & Supplies
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
DickyO
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
I have a IBM Model 5651 Memory Typewriter (Selectric II carriage), and I cannot make the ribbon advance while typing. If I turn the ribbon it will type until the ‘ink’ runs out. It’s just not advancing. ...
If this takes a selectric II ribbon the Spiked driver may be gummed up. Remove the ribbon,
find the latch that holds the ribbon mech. open, release it the ribbon drive should swing freely to the right, if not spray some WD40 on the pivot point, above and below the arm then work it back and forth it should free up.
DickyO
Oct 25, 2010 | IBM Office Equipment & Supplies
Selectric III typewriter
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric used ribbon won't wind into spool
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Jan 29, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric III - ribbon won't turn
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Jan 20, 2008 | Lexmark Wheelwriter 15 Series II...
75 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
