Question about Motorola Walkie Talkie 2-Way Radio
I have a EM1000 and can not the freq from 1 - Motorola Walkie Talkie 2-Way Radio
  • Motorola Master
  • 1,654 Answers
Here is a link to the manual: http://www.giantintl.com/ContentManage/manuals/Moto/EM1000%20User%20Guide%2001-11-08.pdf
Check your frequency, interference eliminator code and Qt filter to be certain they all match one another. You can use the programming instructions to change your frequency.
Posted on Jul 16, 2009
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
How to fix a motorola radio model em200 doesnt
It is possible your radio is not set to the correct frequency and code, and is working but not on the same freq/code as your other units. Here is a link to a similar radio's user guide http://www.giantintl.com/ContentManage/manuals/Moto/EM1000%20User%20Guide%2001-11-08.pdf Possibly using it you will see how to program/check the frequency, code and Qt filter (if any).
Best regards.
Apr 25, 2010 | Radio Communications
I cant talk to the other radio. the channels are both the same.
Here is a link to the EM1000 series user guide: http://www.giantintl.com/ContentManage/manuals/Moto/EM1000%20User%20Guide%2001-11-08.pdf
Check your frequency, code and Qt filter (if any) settings. For basic operations set the code and Qt filters to zero (off). Turn off any special features, and try the radios in just a basic mode.
Best regards.
Apr 09, 2010 | Motorola Walkie Talkies 2-Way Radio
I have a new RCI 2995DX . that after 1-2 mounths it go's off frek
Have you herd it off freq? Do you have a freq counter? How do you know that the person that told you it sounds off freq don't have their receive off freq?
if its on a freq counter, and shows not off freq, then the radio is not off freq. There is some other problem.. Or no problem because if it is just some one else saying it, maybe they are just too picky.
Things that could cause your audio to change. If its in your mobile, diving around will make your audio sound different to people. Antenna or feed line problems. If there is a problem with your antenna or feed line, it could make your audio sound bad or off to some one else.
Also, if this unit has been modded, has the clarifier been unlocked? if so that will change your TX freq.
If the unit is new and nothing has been done to it, there should be no reason why it is off freq unless some one has done something to it.
Feb 24, 2010 | Cobra 29 LTD CB Radio
After entering *#3646633#, I had given assert
code *#3646633#
select : device
select : pmic 6318
select : lcm bl setting
put value as under
level 1
freq 200
duty 20
press OK & again do the same process for below values
level 2
freq 200
duty 40
level 3
freq 200
duty 60
level 4
freq 200
duty 80
level 5
freq 200
duty 100
Dec 24, 2009 | Cell Phones
Constant tone on an HT1000
You will get a constant tone on any channel that isn't programmed. it sounds like the previous user ha a freq programmed on channel 1. Channel 11 is strange, but possible. Usually guys program these radios in order.... they don't put 2 freqs in soo far apart from each other..... I would expect channel 1 AND 2 to have freq programmed in them.... but channel 1 an channel 11 is strange... but possible. Anytime you don't fill up all the channels on these radios (commercial radios in general) you will get a constant tone on the channels that don't have anything programmed in them. Program the radio and your good to go. If you don't program freqs into al the available channels, expect to hear that "constant tone" on any unprogrammed channels. The channels that you hear a tone on do not have a freq programmed into it. Its normal. Good luck
Jul 05, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
120 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
